misfire at 4k revs
Ello guys
Just installed a new engine and its developed a slight missfire at 4k revs.
Spec is 2wd saf,
4x4 engine
hybrid t3 (unknown spec)
using 2wd TPS on 4x4 throttle body
0.63 gapped plugs (ford plugs, says somethin about platinum on em...quite new, never noticed part number)
recently swapped crank sensor as previous one was faulty
collins stg3 chip
greens
4x4 intercooler
around 15psi boost
also using ford BERU leads, in tip top condition
The problem mainly seems to occur when the foot is planted on the floor.......making me think its either the tps or crank sensor.........anyone got any ideas???
Spec is 2wd saf,
4x4 engine
collins stg3 chip
greens
4x4 intercooler
around 15psi boost
map sensor wiring has not been touched since before i put the new engine in...any idea how much for a brand new crank sensor, and would the 2wd TPS using a 4x4 TB be any issue in the problem?
mines the same but only happens when the engines warm (have a collins stage 3 as well) never happened before with the stage 1 but have noticed the phase sensor wires inside the dizzy look shite i have a new one but have yet to fit it (also just fitted a 500 intercooler and yet to try this as well)
lol@ all.
david-il get them one day...when u need em for. i have the best part of a whole 2wd engine in the garage. il swap the dissy caps over when i manage a day off (bloody work-gets in the way of ma 'tinkering')
KSA cossie- i wanted to get the bootlid sprayed b4 i took photos(and clean it too), the new lid is on it just needs flatted and polished. not been able to do it seein as its been rainin ere for about a week or so. pics will go up soon hopefully tho
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
