TWITCY STEERING PLEASE HELP
Old Aug 22, 2005 | 10:04 AM
safflad's Avatar
safflad
Default TWITCY STEERING PLEASE HELP
ok the other day i bust the inner cv on me saff at the same time my p.a.s pump went for a shit too,removing the pump i snapped the banjo pipe , went and fetched new pipe and pump fitted 'em and topped up fluid but now when i turn left the wheels "twitch" Only when i turn left it even does it on the spot even with the wheels in the air
any ideas?
Old Aug 22, 2005 | 10:22 AM
safflad's Avatar
safflad
C'mon lads some one must have an idea
Old Aug 22, 2005 | 10:24 AM
Graceland's Avatar
Graceland
Team HOTHOT!
how you mean "twitch"
do you mean when you apply left lock, and hold it without moving it, its trying to pull the wheels back right and the steering wheel feels like its bouncing?
if so - theres air in there still
Old Aug 22, 2005 | 10:29 AM
safflad's Avatar
safflad
hard to explain really its not tryng to pull the wheel back to centre
is there like some bleed nipple i dont know about - whats the proper procedure for bleeding P.A.S
Old Aug 22, 2005 | 10:32 AM
Graceland's Avatar
Graceland
Team HOTHOT!
it wont try to pull the wheels abck to center - it just feels bouncy
jack the car up at the front so both wheels are off the ground, take the cap off the PAS tank, and then turn the wheel lock to lock 5 times - holding it at each far lock for a few seconds each time so that the pump is working hard
check the level, and top up as required - do this untill all air is expelled
Old Aug 22, 2005 | 10:38 AM
safflad's Avatar
safflad
done that could it be a fault with the rack as i did drive about 3/4 of a mile with no fuid in it
it does bounce like fcuk when i turn left but right its perfect
Old Aug 22, 2005 | 10:42 AM
Graceland's Avatar
Graceland
Team HOTHOT!
best be trying a new rack then
Old Aug 22, 2005 | 10:52 AM
safflad's Avatar
safflad
don't wanna throw a rack/more money at it unless i know or am at least half sure thats the problem
Old Aug 22, 2005 | 10:57 AM
Graceland's Avatar
Graceland
Team HOTHOT!
well its either the rack or the pump - either way, you ran the rack and pump with no oil, so its likely to have caused damage - the pump needs the oil to keep its bearings lubricated and the rack needs it for that reason too
funnily enough i have 2 spares
Old Aug 22, 2005 | 11:00 AM
safflad's Avatar
safflad
bet you live miles from me though I,m near notts
Old Aug 22, 2005 | 11:03 AM
Graceland's Avatar
Graceland
Team HOTHOT!
80 miles from my house to donnington race track
notts aint that far.
and my racks are just that - spares.................for mine as i know mine will need it doing soon
Old Aug 22, 2005 | 11:05 AM
Dean Saff's Avatar
Dean Saff
So you have changed the pump already? was it a new one? If so chances are you've wrecked the rack....
Who did you bust the cv and pump at the same time?
Old Aug 22, 2005 | 11:07 AM
safflad's Avatar
safflad
bugger so your just teasing then
Old Aug 22, 2005 | 11:10 AM
safflad's Avatar
safflad
DEAN SAFF god knows how i bust both at once just my luck i guess
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
