Cossie fuel pump runs continuously - why??!!
Hi all,
My saff cossie fuel pump has recently started to run continuously (with the ignition switched on) instead of buzzing up to pressure and shutting off as normal.
Is this a problem with the fuel pressure regulator? I think a gushing can be heard from the back where the fuel is being returned to the tank
Please help, your suggestions would be much appreciated
Thanks and regards
Weeksy
Thanks and regards
Weeksy
Hi mate,
It is an 89 2WD.
I though the circuit was shut off by pressure, I take it that it is a trime delay circuit with this relay?
Is it a common prob?
Weeksy
It is an 89 2WD.
Weeksy
No, not at all.
As far as I am aware, it's all as it should be. I fitted a 044 pump and new filter. I laid it up for a year or so, and this is what it is doing now!! It had a silly fuel cut off switch in the cassette box, that has been disconnected, other than that, all as it should be!
Team HOTHOT!
its probably the pink fuel relay thats sticking then - they can be a problem as they overheat and the contacts weld themselves together - and since you have put an uprated pump in, i suspect that this is what has happened
Change the fuel pump relay and see how you get on
If it is the problem and all is good after changing the relay, then run some heavy duty 30 amp wire from the battery to the fuel pump and have the original wiring switch a relay instead of the pump directly.
kosienutter
31
22-08-2015 09:55 AM
ekjim
17-08-2015 08:57 PM
CabrioTurbo
01-08-2015 11:04 AM
