Anyone know much about multithrottle + turbo
Old 12-08-2005 | 03:22 PM
Default Anyone know much about multithrottle + turbo
Looks like i will be using ITBs on a blown motor im building.
Little worried about getting a reliable map reading as the way i see it, at part throttle on one cylinder it will see boost (valves closed) and on another it will see vacuum (asusming less air from boost past that part open throttle than the engine is consuming in vacuum on that cylinder)
So whats the best way to do it?
Im guessing on just using a balance pipe running beteen the 4 ITBs?
How do liners do it when they are getting a MAP reading?
Old 12-08-2005 | 03:41 PM
M Brian's Avatar
M Brian
surely you'd still have one plenum though?
run the map off the plenum and it will operate the same surely?
Old 12-08-2005 | 03:50 PM
No because the plenum (which yes you are right i have a single one) is BEFORE the throttle plates, which means the pressure in there isnt the same as the pressure in the manifold as you get a pressure difference after the butterfly when its only partially open, what you say would be fine on WOT though.
Old 12-08-2005 | 04:10 PM
leecavturbo's Avatar
leecavturbo
for a vauxhall engine chip ? if so you can get inlet manifold with injector ports but with no butterflies ,bolt on ya plenum and one fat throttle valve at the mouth of ya plenum job's a good un
Old 12-08-2005 | 04:31 PM
ECU Monitor Enthusiast
Chip,
In this scenario, ecu's use a combination of MAP and TPS to estimate the fuel
demand during throttle closed/vacuum conditions.
Generally TPS is used ONLY for load calculation at say below 10% TPS and between
10% and 25%, a combination of 50/50 is used.
Above 25% then only map is used.
These figures are estimates as it WILL vary depending on engine design.
Old 12-08-2005 | 04:32 PM
Graceland's Avatar
Graceland
Team HOTHOT!
how did they do it on one of the random powered jap motors?
Old 12-08-2005 | 04:44 PM
lee, yeah i may be able to do it that way i guess, and just use a single throttle before the plenum, would have prefered this way though, if only cause ive got a spare set of bodies lieing around that fit perfectly!
SECS, hmm, not sure how i could set DTA up to do that, you have to either pick TPS vs RPM with MAP as just an adjustment or vice versa, you cant do half and half as far as i know.
Anyone else got any useful input?
will my theory with balancing MAP out using a balance bar not work for any reason, if so why?
Old 12-08-2005 | 04:55 PM
Jamz's Avatar
Jamz
The Pulsar GTi-R has quad tb's and runs a hot wire MAF sensor rather than a MAP.
Old 12-08-2005 | 05:11 PM
gtir430's Avatar
gtir430
ive run a map sensor on the quad throttle bodies(on a gtir) and its no problem u just rig the pipes from each port together and take a signal from that
Old 12-08-2005 | 05:49 PM
AlexF's Avatar
AlexF
Like has been said above...
Guesstimate (map/TPS).
Switch to a hotwire/hotfilm air mass meter.
Or run a vac plenum chamber.... inter connect all the TBs to a common closed chamber and take the map reading from there.
Alex
Old 12-08-2005 | 06:13 PM
Nick-T's Avatar
Nick-T
Like SECS says, a combination of MAP and TPS.
A management system like the new Gotech on my Escort can run like this.
Old 12-08-2005 | 06:37 PM
leecavturbo
i'm sure if you really wanted to you could drill and tap a hole after the butterfly ,maybe even all four and connect the four together pipe wise and then to your map sensor
Old 12-08-2005 | 08:04 PM
Mark Shead's Avatar
Mark Shead
Chip use a balance pipe between the 4 TB's then a single pipe to a mapsensor,
This is how the GTR's work I have just mapped 1 with 1680cc Injectors with Autronic's Throttle/pressure mapping, Main fuel table TPS up to 100% then Boost pressure, Ignition table is map/pressure based,
I mapped this in 9 presses of the Accle to 2.2bar boost this system works floorless
Mark
Old 12-08-2005 | 08:19 PM
Jim Galbally's Avatar
Jim Galbally
do tell
(and no DONT say "buy the mag and see" )
Old 12-08-2005 | 08:29 PM
leecavturbo
Mark
just as i said then
Old 12-08-2005 | 08:30 PM
leecavturbo
Mark
i so wish you mapped dta god of mapping
Old 12-08-2005 | 08:34 PM
Mark Shead's Avatar
Mark Shead
leecavturbo, The GTR also has a small plenum also just to stop the pulsing but this doesnt stop the vastly diff flow when the throttle is opened and closed, the Ecu will need its own style comp table/mutli maps for this.
Thanks Mark
Old 12-08-2005 | 08:35 PM
Mark Shead's Avatar
Mark Shead
leecavturbo, If you brought Autronic you wouldnt be wishing that
Mark
Old 12-08-2005 | 08:47 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Or maybe if you BOUGHT it, that would work too
Old 12-08-2005 | 08:51 PM
leecavturbo
^NUTTER^,
just noticed your location , i saw/heard you going up the A5 near brownhills @ about 6pm the other night ( donnington visiting ? ) looks/sounds good
Old 12-08-2005 | 08:55 PM
Rick's Avatar
Rick
Autronic doesnt need mapping on the fuel side, it does it itself. Get to Stu lee, he can map anything.
Old 12-08-2005 | 08:57 PM
NMS Badboy^NUTTER^
Best it's ever been at the moment
Cheers for the comments
Old 12-08-2005 | 08:59 PM
leecavturbo
bit contraversial me thinks, but yeah hav concidered stu @ msd
Old 12-08-2005 | 10:41 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Use a MAF sensor, read the airflow entering the turbo, and have a clever ECU on the other side?
Old 13-08-2005 | 12:35 AM
stevieturbo's Avatar
stevieturbo
C**t
Another question. What are the expected gains over a good sized single throttle and decent inlet manifold/plenum ??
Is it enough to make it worth the hassle ?
Old 13-08-2005 | 12:39 AM
GARETH T's Avatar
GARETH T
speed density throttle angle, with a balnce chamber
Old 13-08-2005 | 12:40 AM
GARETH T's Avatar
GARETH T
well i think i should of read everyones replys and im a little slow
Old 13-08-2005 | 12:56 AM
Cam's Avatar
Cam
Mark
1680cc
Old 13-08-2005 | 01:00 AM
Cam's Avatar
Cam
I can only speak for GTRs but the the std 6 throttles/plenum are supposed to give better response/torque than one large single butterfly/plenum but for ultimate top end power the single has benefits.
Cam
Old 13-08-2005 | 01:09 AM
Mark, thanks for that, much appreciated, looks like i was thinking along the right lines.
re: amm
I dont like airflow meters (or air mass), would prefer not to use one if i dont have to.
re: hassle
Its not any hassle ive got them sat here complete with a manifold and plenum all made up ready to bolt on, so providing i can get a half decent map sorted its not an issue.
cheers everyone for your input
Old 13-08-2005 | 09:34 PM
muppet's Avatar
muppet
This was how I did it on my old mini.
Basically a small chamber where all 4 inlets go to.
vac signal was around -14hgmm to -15hgmm and the idle was a bit awkward to be keep balanced but I think that may have been more down to the throttle linkage. After that I made a single throttle plenum/inlet and vac was closer to -22hgmm and idle was much better to control.
Also I am pretty sure the gti-r has a chamber where all 4 vac pipes go to situated under the the manifold.
Regards muppet.
Old 13-08-2005 | 09:38 PM
AlexF's Avatar
AlexF
Mark
just as i said then
and I said 1st
Old 13-08-2005 | 10:17 PM
stevieturbo
C**t
A turbocharged redtop Mini ???? I'm guessing thats pretty quick !!!!!!
Old 13-08-2005 | 10:27 PM
sbd16v's Avatar
sbd16v
Mark
just as i said then
which is exactly what me and chip were saying 2 weeks ago
i guess he just wanted some different opions
Old 13-08-2005 | 10:38 PM
Mark V8's Avatar
Mark V8
Default Re: Anyone know much about multithrottle + turbo
I run ITB's on my bike and plumbed all four vacuum lines together (taken from the engine side of the throttle plates) and use a small restrictor jet in the single line that goes to my Map sensor. My MegaSquirt ECU uses revs and manifold pressure to calculate fuel and only uses TPS for Accel enrichment.
Mark
JK12
33
26-04-2021 01:09 PM
RSBryden
06-09-2015 09:39 PM
cozzzzy power
04-09-2015 09:14 AM
turbowag
03-09-2015 09:07 AM
Jerry Ryan
02-09-2015 09:02 PM
Quick Reply: Anyone know much about multithrottle + turbo
