Metal ticking noise when engine is warm ???
Ex Ford Man
What could it be ?
Coming from the cam pully side.
I've changed the valve springs and tappets
It only does it when the engine/oil is warm
Was there any play/wear in the bore when you had the engine out? My old red RST had a tapping noise like yours, it only happened when hot.
I replaced the cam and tappets but turned out to be play in the bore of the block.
Mine was 3 snapped exhaust manifold studs, had exactly the same symptoms.
Only did it after i had given it a good boot!
Friend said it was the noise the valves make just as they open/close, when the manifold was warm it opened up a very small gap which made it possible to hear them
track.focus'd
12-08-2015 05:53 PM
