Problem with my sapph 4x4 : HELP PLEASE
The fan/heater in my car stopped working today.
1. How do i go about fixing this ?
2. Car appears to be running smoothly but after a 20 mile run on dual carraigeway at about 90ish i opened the bonnet and the coolant water was bubbling a little in the header tank and i could hear it in the coolant pipes. Been told before that this can be normal in a cossie but should i be worried ??
3. Are both these connected ?
Thanks peeps
Thanks peeps
link the 2 wires on the temp sender if the fans cut in chage it or put a switch inline
or if not put a temp line to the other side of the temp to make them work with a switch
I mean fan/heater as inside the car not the fan/radiator in the engine bay, that cuts in fine when i stop the car.
Also, is it normal for the coolant water to bubble a little ??
Sounds beyond repair to me. NO Heaters IN SCOTLAND
Bring it up and i'll give you a good price for it against a TD Rasta Van
Nah seriously if you are still struggling at the weekend just pop up and i'll have a looksie for ya
It is normal for bubbles to appear from the turbo coolant return, but only from this pipe.
If your heater fan isnt working, check the fuse first of all, then check the resistor assembly
The two are probably not related!
Neil.
Neil.
Some answers
Blower has stopped altogether ?? Whats this mean ??
The coolant water bubbling, Is this normal or connected to my heater problem.
Im not technically gifted !!
Not connected Seems strange they have both started happening together
Why is the coolant in my header tank bubbling its only a wee bit
Has it down to MSD last month and Stu said engine was fine
Look carefully and see where it's coming from - I bet it's the turbo return
It bubbles because the turbo is f'kin hot!
The blower has likely packed up for an entrely different reason - it could only EVER have a very very small effect on coolant temps if you were running the heater on hot, and the fan on full...
Neil.
Neil.
Adam Graham
06-09-2015 06:04 AM
