help getting the flywheel bolts off.. erst
hi all, im trying to get my flywheel off on a erst, now when you put a spanner on the crankshaft bolt to hold it so you can undo the flywheel bolt the crankshaft bolt just comes loose?? whats the crack to take the flywheel bolts off, what can you jam to undo the bolts??
thanks
andy
thanks
andy
thanks
andy
thanks
andy
i used an air ratchet on mine works fine if you dont have one i suggest you try to find someone who has one
Otherwise you will be left with the option of trying to jam the flywheel or crank with something.. the later certainly wouldnt be my first choice and the former is normally less than sucesfull
cheers mate just seen the pic in the haynes
andy
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
andy
does it tell ya to doit how i said?
You need two people to do it that way though needs one putting pressure on the bar and one undoing the bolts
failing that i did this.
get some rope. run it round the fan belt pully a few times over its self and make sure u do it in the direction that when u try to undo the flywheel it all binds up and locks the crank in place.
then tie the rope to something else solid on the engine, something like the alternator bracket.
that way you can do it all by ur self.
Good old fashion roman stuff!
Mc5506
05-10-2015 09:57 PM
