Whats needed to 4x4 a 3dr?
30-07-2005, 11:42 PM
Looking into options for bringing the 3dr back to life
What exactley is needed to 4x4 it?
What box,diffs would be needed for 400bhp?
Cost?
etc etc
Thankyouplease
31-07-2005, 06:26 AM
basically the whole front end and box from a 4x4,plus the sump and some fabrication to the transmission tunnel.
31-07-2005, 08:20 AM
standard will handle 400BHP if rebuilt properly
I did a full season of Hillclimbing on mine, lots of full throttle starts and other people said it wouldn't last, if it built properly it WILL last
31-07-2005, 08:30 AM
Mick320bhp has just 4x4'd his 3 door. keep this post on the first page & i'm sure he will be able to help you.
31-07-2005, 09:03 AM
cant believe you thinking of this after all your moaning about 4x4 transmission!!
would be cool if you did it tho!
31-07-2005, 09:55 AM
Don't forget the gearbox tunnel will need a bit od modding so the diff and tthe front prop will fit.
Nothing a big hammer will not sort.
Need a mount aswell for the gearbox,slightly different place to the 2wd one.
Dave.
31-07-2005, 09:56 AM
Jeebus
Been covered loads of times, do a search
31-07-2005, 10:01 AM
31-07-2005, 11:07 AM
So basicly its not a major headache
31-07-2005, 11:16 AM
flat blade, file and a pair of mole grips should surfice
31-07-2005, 11:23 AM
Quote:
Right im off to Halfords in that case
31-07-2005, 12:36 PM
but its to early the boyracers dont come out till 8
31-07-2005, 12:42 PM
if your going to use your engine then all you would need is
4x4 sump
front diff
driveshafts
4x4 cradle maybe rack
front prop
4x4 gearbox
rear prop
also modifications to the gearbox tunnel where the transfer box will sit and also to front chassis legs, half moons need to be cut out for the front driveshafts
31-07-2005, 01:38 PM
Norris Motorsport
Don't forget in addition to above list you will need 4X4 front hubs, struts and brakes as your 2wd brakes wont fit the 4X4 setup.
31-07-2005, 01:44 PM
Cheers chaps
What kinda price am i looking at for this lot plus labour?
31-07-2005, 01:51 PM
if your mechanically minded then its very straight forward to do
if not then good be quite expensive as theres a lot to change over
31-07-2005, 01:53 PM
My talents stretch as far as an oil change
31-07-2005, 01:55 PM
ok then
im sure theres a repyuable tuner that can do it around by you or brum ways
maybe reyland or or zoo motorsport in brum
at least you know its done right
give brom a pm sure he can help
31-07-2005, 01:56 PM
Have to dig deep then.
Dave.
31-07-2005, 01:57 PM
Dave.
That makes a change with cossie ownership then
IAN RS2k
18-08-2015 07:51 PM
c20tbo
17-08-2015 10:19 PM
col93saphcos
07-08-2015 03:21 PM
paceo
12
04-08-2015 08:50 PM
ricky
31-07-2015 10:30 PM
