********DESPERATE HELP NEEDED RST Engine Problems Now Fixed
Old Jul 24, 2005 | 06:10 PM
MK5RST's Avatar
MK5RST
Default ********DESPERATE HELP NEEDED RST Engine Problems Now Fixed
One day it runs fine the next its firing on 3 Ive had problems ever since i did the install, last week i thought i had it spot-on and i came to start it this week and its running lumpy, theres no diference when i remove no 1 and 3 HT leads and removing the oil cap doesnt cause the revs to rise, any0one any idea where to start as ive run out of ideas to try
Old Jul 24, 2005 | 06:17 PM
Šhatter Box's Avatar
Šhatter Box
removing the oil cap it should cut out and die do a comp test then ur know where ur stand but dont sound to good to me
Old Jul 24, 2005 | 06:18 PM
MK5RST's Avatar
MK5RST
Have done a comp test and all 4 are the same within a few psi, the dizzy is new, cap and leads are new
Old Jul 24, 2005 | 06:24 PM
xr4x4rs's Avatar
xr4x4rs
change your leads again
sounds like there breaking down
even if they are new
put some plugs in aswell
see if that helps
Old Jul 24, 2005 | 06:29 PM
MK5RST's Avatar
MK5RST
Yeah, gonna go for some decent plugs and leads, any recomendations on the leads and plugs, plugs are for standard boost and standard fueling
Old Jul 24, 2005 | 06:48 PM
MK5RST's Avatar
MK5RST
NGKBCR8ES any good and mafco Pro Leads?
Old Jul 24, 2005 | 07:03 PM
xr4x4rs's Avatar
xr4x4rs
alls im running is the same plugs as u mentioned there
and just some leads form an car accersorie shop
nothing fancy and havnt had a problem yet
but i supose the best are magnecor but not to sure
Old Jul 24, 2005 | 11:53 PM
digita1dragon's Avatar
digita1dragon
everyone reccomends motorcraft. Ł30 a pop now tho!
Old Jul 24, 2005 | 11:59 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
sOUInds like its' fucked to me
Old Jul 25, 2005 | 06:07 PM
MK5RST's Avatar
MK5RST
Does to me too buy hey it needs fixing
Old Jul 26, 2005 | 06:33 PM
MK5RST's Avatar
MK5RST
Sorted the BRAND NEW Bosch plugs were to blame now running NGK,s, its sweet as a nut
Billy_RS
16
Oct 11, 2025 09:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
