Fitting a T5 to a 3-door GL shell?
ok, chip has told me that the cossy gearbox cradle thing wont fit the GL shell as it doesnt have the slider things?
so is there anyway i can use the type 9 cradle on the T5?
i dont mind drilling a hole straight though the floor and using bushes etc
Yes i reckon you can modify it to fit the type 5 cradle mate, just wont give you the same sort of adjustment.
What year is your shell though, i believe from C reg onwards they may have changed, mine is only the way it is cause its pre-cossie (A reg in my case)
are they really necassary tho?
i mean, as i dont know much about the 3-doors, once its all bolted up is there much room for adjustment?
basically i think im gonna struggle to get the slider bits really, hence just fitting all the engine and running gear, and then where the cradle sit just drill through the floor and bolt it up
Just makes it easier to install the engine and box, and given that you will be fooking around moutning a different engine anyway, i would have thought that element of movement would be invaluable.
Plus if you dont i will take the piss out of you constantly, referring to you as a "nonslider dodgy replica owner", cause im a bufty with sliders and im getting it written down so it says so on my logbook and i will look down on you if you dont
Every saff ive seen has the 'sliders' in the tunnel so what about chopping some out and welding them into your shell not that difficult if your decent with a welder or wont be expensive to get someone to do it either.
Originally Posted by fudgeass
well ive never done welding before but ill give it a go
so any 2wd saph shell with have then? non cos etc?
i dont really know what they are tbh
Near the bulkhead in the tunnel but dont know what will be there on your shell, nothing probably. If youve never welded before then i'd get someone to do it for you mate
And Chip big for you mate, well I couldnt find a gold star
the change over year for the sliders was 84 so you might get lucky!
magnum engineering do a DIY cross member kit for the T5 into an early shell i believe, not sure what it consists off though? you might have to weld it together unless they designed it to bolt together
Testing the future
4x4 is different, there's no slider in the right place for t5 x-member as that's where transfer box sits. so make sure you get the bit of floor from a 2wd shell.
Injectors:
http://www.racetronix.com/17113738FM.html
CHECK THE IMPEDANCE IS OK FOR WHATEVER ECU YOU ARE USING!
i would have thought the easiest job would be modify a 3 door T5 crossmember to fit your floorpan, the 3 door one is steel rather than alloy like the saph cross member...
yeah the type 9 ones are steel too, problem is the cossie rubber mount is completely different, the type 9 box has only one fixing point dead center, but the T5 has 2 points either side of center
It would be alot easier to just make up a new crossmember, to fit your car
once you have the engine and box,in place. Mine has the sliders, but didnt
use them, the steel to make a new cradel cost about 8 quid, and i used
escort engine mounting bushes, about 3 quid each, and it only took a couple of houres to make, It took longer to drill it all out to lighten it
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
