RE The Texaco RS500 touring car......very interesting...
Had a long chat with Martin (Martin500labbats) yesterday at the Beulieu Show, he had his Texaco RS500 touring car on display, this is one of the Ruddie Eggenberger built cars from Germany..........
Lots of differences between the way it's built compared to the Andy Rouse UK cars - BUT LOOK (pics):
1. Two fuel rails (as homolgated), the outer fuel rail has 4 x yellows and the loom connectors fitted - BUT no fuel line/fuel supply (i.e. dormant rail).
2. The inner fuel rail is made of 1" (25mm) box section and has 4 BOSCH 1000cc injectors fitted!!! This was back in 1986/7...........so how far advanced was Rudie's spec....no wonder they were hostile to Andy Rouse coming anywhere near their pit garage to have a look at the engine bay.
Will put up more pics in a while, including the HUGE Bosch water cooled ECU (about 40cm square amd 70 cm thick)........
Originally Posted by Itsmeagain
no vernier pulleys?
Originally Posted by Neil S
Well spotted!
Maybe they used offset keys though Steve
Neil.
Neil.
Obviously you can only make a couple of degrees difference on keys, but thats enough probably.
Fascinating looking car that, real piece of history, im jealous as hell
no vernier pulleys?
no vernier pulleys?
no vernier pulleys?
A certain tuner on here (he builds proper big power engines) is quite happy to avoid verniers
If asked by the customer, he will time up the cams by REMOVING the keys.........therefore setting up the timing (on engine dyno) and then tightening up the nut to the new settings.........as long as the nut is properly tightened it is safe.
All down to personal preference, but as you say the nut (well bolt actually, not that it matters!) tightened properly should hold it in place well enough, especially if its a race engine and hence only run for a few hours between rebuilds anyway.
no vernier pulleys?
Oh i see,thats how you do it
i guess the std DV had to be used for homologation reasons too?
It's also connected arse-about face!
Neil.
They all made backwards
Steve, you NEED to fit those DV's mate.
Your "Zero to Three" time is going to suffer massively if you dont, it could be increased several times over in fact, some vehicles have shown increases in time of up to 300% by removing the atmospheric DV!!!!
Didn't some of the touring cars use a Zytek ECU?
The Zytec ECU are the ones where you can manually adjust the fuel and the ignition from knobs on the front as I remember.
As Chip said though these Ecus are pony now though, but well worth having if your car is a genuine piece of history like Martins are
what a great car!
if anyone ever says 'the RS500 touring cars'
i always seem to picture the Texaco ones in my head. lol
must be brillient to own a piece of history like that!
here you go,
my labatts car still has the zytec ecu fitted, and that works fine,
but as i am racing the ANZ car we removed the zytec system and fitted the tryed and trust good old L8 with pectal baby board, as we now use air to air injectors for the T4,
also removed as it was not needed was the rouse mechanical fuel pump,
that now sits on the spares shelf,
new loom, was needed anyway as the original was bit second hand looking, so apart from the ecu ect, its basically how rouse would have had it,
i fitted a pectal moniter to replace the exaust senser gauge, so i can moniter lots of info on the same unit,
