2WD COSWORTH TOO HOT !
Old 13-07-2005, 09:39 PM
rabmc
rabmc's Avatar
Default 2WD COSWORTH TOO HOT !
Basically my header tank (alloy spec r ) gets absolutly ROASTING HOT can hardly touch and get a fair bit of pressure if tryin to open cap but is not that bad if let my fans go off, and if i have been giving it some i.e 120ish+ it seems to be spraying water from somewhere ? is defo coming from header tank i.e cap fans come on as usual and go off , and car drives and runs great but this water temp thing is puzzling and annoying the tits off me temp sits between O and R on guage when driving round it is stage 3 with pace rs500 cooler , so any ideas guys on this could it be anything to do with my rad
any help appreciated
Old 13-07-2005, 09:57 PM
ECU Monitor Enthusiast
possible head gasket failure at worst or header tank cap worn out at best !!!
Old 13-07-2005, 10:00 PM
rabmc
rabmc's Avatar
Basically tonight i put my mates cap on (same cap) mines made a horrible squeeking noise on tightening and his went on without any of that but didnt go out a run but mines looks fine ? would this make a difference on pressure guys i find it strange that cap would be a big deal
Old 13-07-2005, 10:02 PM
david
david's Avatar
Yeah Rab I had a fucked cap on the grey car and it was similar to what you describe mate, swapped it for another and all was fine
Old 13-07-2005, 10:08 PM
The cap is NOT just a cap !!!
It is a pressure relief valve aswell and when it wears, it releases pressure and water TOO soon.
They are only £2.99 from ford
Old 13-07-2005, 10:14 PM
Alvyn
Alvyn's Avatar
r u being serious on this post the header tank is hot to touch once I've given the car some come on man thats like saying "why cant I touch the exhaust manifold to remove the nuts once I've started it" change the cap lol
Old 13-07-2005, 10:26 PM
rabmc
rabmc's Avatar
LOL
Yeah does sound stupid , no but think its just TOOOOO HOT does the ford water caps fit the spec r alloy header tank ? mines is kind of dark blue in colour
Old 13-07-2005, 10:27 PM
gazcos
gazcos's Avatar
If you dont replace the cap you may well find that when you next undo it , it will fall apart. Mine did that. The cap came of but the bit inside with the rubber sealing ring was stuck on the tank neck LOL
Old 13-07-2005, 10:29 PM
rabmc
rabmc's Avatar
What kind of tank did u have gazcos , what kind of cap do i need do i need a spec r one or bailey ? my friend has a bailey tank and his cap is identical
Old 13-07-2005, 10:35 PM
gazcos
gazcos's Avatar
I cant remember without looking. Its not the one in my siggy, its on my Saph but it uses a standard Ford cap . The tank on my 3 door was a Bailey one and used a Bailey cap (smaller than a Ford one )Hope that helps
Old 13-07-2005, 10:37 PM
Alvyn
Alvyn's Avatar
Originally Posted by rabmc
LOL
I have a Spec R with sight glass have a yellow standard Ford cap for a Cossie on it and If run for about 5 mins or less I CANT undo it with my hands and need to use a pair of side grips(like molegrips) and YES the tank itself does get very hot
rabmc
rabmc's Avatar
mmmmm wonder if they do the cap seperate mmmm will phone tomorrow
thanks for the help although will be suprised if this cures the pressure etc , but some of yous guys have seen this before so will take your advice
thanks alot for the replys
Old 13-07-2005, 10:39 PM
rabmc
rabmc's Avatar
LOL
Good so ford ones dooo fit mm lol how hot we talking
Old 13-07-2005, 10:46 PM
Alvyn
Alvyn's Avatar
well let's just say when I have my bonnet open have had so many people that while having a nose place their hand/arm on it and they ALWAYS seem to jump about with the pain so hot hot hotvery hot
ps I think Bailey's use a darky blue coloured cap(sort of domed shaped) IIRC
Old 14-07-2005, 10:21 AM
Stoo
Stoo's Avatar
My cap squeaks when going on and off? Does that mean its replacement time?
Also,mine is black,not the usuall ERST yellow..?
Old 14-07-2005, 11:35 AM
Disabled Account
Disabled Account's Avatar
Edited (thanks to Spenner):
Yes Alvyn, the Bailey header tanks come with a higher pressure cap (i.e higher pressue than the standard Ford yellow cap)......
The Bailey tanks use the Audi/VW dark blue pressure cap, important to note that these caps have a different diamater & thread size to the Ford items, so you cant just fit these dark blue VW caps to a Ford plastic header tank or to "some" Spec-R header tanks.
Old 14-07-2005, 11:54 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
i can't touch my nice shiny stainless steel kettle either roflol can any one help
Old 14-07-2005, 11:56 AM
Turbosystems
Super Moderator
the cooling system is pressurised to prevent it from boiling, water boils at a much higher temperature when pressurised
Hope this helps
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
The Pain
Old 14-07-2005, 11:58 AM
Turbosystems
Super Moderator
can't under stand it stu it's fine when it's full of cold water do u think it may need live mapping
Old 14-07-2005, 12:57 PM
CraigN
CraigN's Avatar
sounds just like mine used to be
this was the cause
Old 14-07-2005, 01:23 PM
Stoo
Stoo's Avatar
Originally Posted by Doug Stirling
The Bailey tanks use the Audi/VW dark blue pressure cap, important to note that these have a different thread to the Ford caps, so you cannot just fit these dark blue VW caps to a Ford or Spec-R header tank
Why not mate?
Mine is a dark blue cap and fitted to a Spec-R header tank.Should i change it to a standard header tank cap?Car run's hot
Old 14-07-2005, 03:44 PM
Disabled Account
Why not mate?
Edited: Please see Spenner's reply below.......
Old 14-07-2005, 04:03 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Alloy header tanks always get red Hot
Old 14-07-2005, 04:52 PM
rabmc
rabmc's Avatar
Will change cap lads and tke it from there was told by spec r today they had alot of problems from these caps on there stuff and they dont use them anymore so he did tell me a part number and i can get one from VW/AUDI garage
Old 14-07-2005, 07:02 PM
Beach
Beach's Avatar
can't under stand it Stu it's fine when it's full of cold water do u think it may need live mapping
Im still hurting now
Old 14-07-2005, 07:05 PM
rabmc
rabmc's Avatar
ROLFLMFAO
do u think im paranoid then troops
Old 14-07-2005, 07:19 PM
Lee Reynolds
Lee Reynolds's Avatar
rabs got cossie paranoia. Welcome aboard
Old 14-07-2005, 07:30 PM
spenner
spenner's Avatar
Pete at spec-r made some tanks with blue vw cap but generally they have standard ford yellow caps they are not interchangable they have different necks pete now generally uses radiator caps these are high pressure i think you can send your tank back and for a charge pete will change the neck. The standard ford cap is i think 1 bar and rad type neck is 1.5 bar . Out of interest the standard cap is generally fine if in good condition
Old 14-07-2005, 07:43 PM
rabmc
rabmc's Avatar
spenner this is what pete said to day he said if i send him my cap (i think he said only cap) he could mod it too like radiator style and nothings upsetting this thing told me to pop into VW/AUDI garage as well
Old 15-07-2005, 08:49 AM
Stoo
Stoo's Avatar
But....I never got a cap with my Spec-R tank I just used the cap from my plastic header tank when i changed them over,it just happened to be dark blue?
Im confused as hell right now.Never thought id be concerned about a header tank cap,cheers Rab
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
MARKYMARKONE
20-08-2015 12:55 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: 2WD COSWORTH TOO HOT !
