Bleeding S2 Brakes
Old 13-07-2005, 04:22 PM
PhilM
PassionBMW.com Member
PhilM's Avatar
Default Bleeding S2 Brakes
Anyone able to offer some advice?
The car has een stood with the brake system dry for about 1month. Its had new calipers, enw wheel cylinders, and braided pipes.
Anyway, I set about bleeding the system, starting at the drivers rear, pass rear, drivers front then pass front.
Buuuut, after bleeding until theres no more air coming out, the pedal still goes to the floor under reasonable pressure. Although if you pump it quickly it builds up.
There are no leaks I can see around any of the new pipes/fittings...so thats ruled out.
Also, aside from the spongy pedal, when you release the pedal having depressed it, it sometimes sticks a bit and then "bangs" loose, (a little bang/click).
Any ideas?
Many thanks
Old 13-07-2005, 04:25 PM
Wazzzer
Wazzzer's Avatar
Make sure you did them with all 4 wheels on the floor or the conpensators will mess it about
Also you have to do the front right and rear left together and the rear right and front left together as they are on the same line (split on the inside wing via a T piece)
Do you still have ABS?
Old 13-07-2005, 04:33 PM
PhilM
PhilM's Avatar
Thanks
ABS is gone. I did them in the order above, so I guess I need to do each circuit at a time? (Front Left, Back Right etc).
Also someone pointed out I may have to remove the vacuum if any from the servo...?
Old 13-07-2005, 04:47 PM
John Laverick
John Laverick's Avatar
Also it sound like to me that your rear drums could possibly be worn [have the drums and shoes been repalaced at all?]
I had a similar problem with the pedal going to the floor...turned out the internal diameter of the drum was two large....the first pump pushes the shoes out and the second pump pushes them onto the drum.
Old 13-07-2005, 04:49 PM
PhilM
PhilM's Avatar
Drums have new shoes and new wheel cylinders, drum cover itself is the same.
Old 13-07-2005, 04:56 PM
NUTS RuS
NUTS RuS's Avatar
You just won a coconut Phil
Old 13-07-2005, 04:59 PM
John Laverick
What do you mean the same?
If its new its obvioulsy ok....if not did you check the internal diameter to make sure its not past its max wear?
Old 13-07-2005, 05:05 PM
big_wig_074
big_wig_074's Avatar
hope its ok,i just took him thru the mk3 escort haynes manual,hope its the same!
Old 13-07-2005, 06:41 PM
PhilM
PhilM's Avatar
Thanks to everyone who offered assistance, especially Greig for reading the manual to me
All sorted now, was a bit of trapped air, it came out eventually.....
Old 13-07-2005, 06:44 PM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
also helps if you load the boot up a bit.. opens the load valve more
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Bleeding S2 Brakes
