Squeaking / Knocking / Banging Noise!
Old Jul 5, 2005 | 04:24 PM
Poom's Avatar
Poom
Default Squeaking / Knocking / Banging Noise!
Hi Guys,
I have a dodgy knocking type noise coming from my passenger side!
It happens all the time now!
It has happened since I de-greased underneath my engine on Sunday because it had shit loads of oil under there so I have a feeling I could have de-greased something I shouldnt have? One of my CV Gaitors were a bit dodgy so could it be this?
Old Jul 5, 2005 | 04:38 PM
Alvyn's Avatar
Alvyn
check the drive shaft still has grease in it
Old Jul 5, 2005 | 05:06 PM
Poom's Avatar
Poom
I will get some grease tommorow and check this tommorow night!
If I need to grease it, will I need to take the drive shaft out to do it or can I just jack the car up and do this?
Old Jul 5, 2005 | 05:10 PM
digita1dragon's Avatar
digita1dragon
If the boot is alright dude you can just pull it back, apply grease then secure back on. I dont know where you can buy the special clips though, Ford only sell them as part of a kit
If the boot is split or knackered it means you have to pop the shaft out and get a cv boot kit! (Not in that order preferably! )
Old Jul 5, 2005 | 05:14 PM
Alvyn's Avatar
Alvyn
If I need to grease it, will I need to take the drive shaft out to do it or can I just jack the car up and do this?[/quote]
what car is it btw, if the gatters are ok then all you need to do will cut the clips and pull them back and pack bearings and cup out with grease and recover with cv boot and cable tie in place. if the gatter is split then you will have to remove shaft to put new gatter on etc!
Old Jul 5, 2005 | 05:15 PM
Poom's Avatar
Poom
I think the boot is fookd to be honest so I will get a new kit! How hard is it to pop the shaft out and put it back in again?
Old Jul 5, 2005 | 05:16 PM
Poom's Avatar
Poom
series 2
Old Jul 6, 2005 | 12:15 PM
Poom's Avatar
Poom
Just took it to a propshaft place and they jacked it up and the wheel nearly fell off!
The wheel bearing was shagged as well as the flange where the wheel goes on! (Tried not to giggle at flange)
Ł122 quid later and it should be sorted by half 4!
Old Jul 6, 2005 | 12:57 PM
It's Czech Mate's Avatar
It's Czech Mate
Where did you take it mate?
Old Jul 6, 2005 | 02:08 PM
Poom's Avatar
Poom
It is a place called Dave Mac Propshafts in Coventry! He was a nice bloke, he showed me exactly what was wrong, how the parts worked and what they were for so I understood what I was paying for! Top chappy!
Old Jul 6, 2005 | 04:04 PM
Poom's Avatar
Poom
Just got it back!
Feels a lot smoother to drive and got discount too
Old Jul 6, 2005 | 04:28 PM
xr4x4rs's Avatar
xr4x4rs
told you hes a good bloke
ive always took my cars there for driveshafts, propshafts and beraingsd
he even made me a stronger propshaft for the cossie
Old Jul 6, 2005 | 04:30 PM
Poom's Avatar
Poom
Yep I see what you mean!
the first car type place where they havent just been after my money and took the time to make sure I knew what I was buying
(as you know I knew fook all about cars)
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
