How do i get the bottom pulley off on my 2wd saff??
Old 22-06-2004 | 08:37 AM
Spiky's Avatar
Spiky
Default How do i get the bottom pulley off on my 2wd saff??
it just would not budge,
How do you do it?????
cheers
Old 22-06-2004 | 08:39 AM
Pully puller......
Old 22-06-2004 | 08:41 AM
3drstretch's Avatar
3drstretch
As said above BUT watch you dont snap off the lugs that the crank sensor picks up on.
Spiky's Avatar
Spiky
and if you dont have one
Old 22-06-2004 | 08:42 AM
Spiky's Avatar
Spiky
actually i meant how do you undo the BOLT
SapphyMike's Avatar
SapphyMike
Just use a big hammer, that'll shift it
then you'll need to spend around £100 for a new bottom pulley (what it cost me when mine had to be replaced by a previous owner not having a pulley puller)
Old 22-06-2004 | 08:43 AM
SapphyMike's Avatar
SapphyMike
Is the engine still in the car Spikey? if so, put it in something like 4th gear and get someone to put their foot on the foot brake while you undo the bolt.
Old 22-06-2004 | 08:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Pully puller......
sometimes known as hub puller.
is the engine out? otherwise you don't have a lot of space to use one.
if you haven't got one, how about warming the pulley up with a gas torch?
3drstretch's Avatar
3drstretch
With a 19mm socket (i believe) you numb nuts.
Old 22-06-2004 | 08:47 AM
Spiky's Avatar
Spiky
that didn't work
Old 22-06-2004 | 08:48 AM
Spiky's Avatar
Spiky
24mm, dumb ass
and it was paul trying, so dont blame it on my ickle strength
it's still running old cam belt untill we can change it
oh and stretch, my bufty ways are catching up
Old 22-06-2004 | 08:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
ideally you want to use an air hammer action wrench jobber or even one of them electric wheel nut hammer action tings.
it's hopefully got threadlock on it, and these should break it open.
3drstretch's Avatar
3drstretch
If paul doing it.Is head still off.If so tell him to take off starter motor and lock flywheel with a big fook off screwdriver then turn 24mm socket.May need 2 of you
Aaaaaaaaah the way of the bufty my son
Old 22-06-2004 | 08:51 AM
Neil S's Avatar
Neil S
Pull harder then
To get the pulley off the crank, DONT use a puller that hooks round the back of the pulley - you will likely muller it.
You need the type that bolts into the holes in the pulley (they are there for a reason )
Probably need to remove the rad first
Neil.
Old 22-06-2004 | 08:53 AM
Disabled Account's Avatar
Disabled Account
that didn't work
Remove the starter motor, then use a decent size screwdriver (large with flat end) to lock up the flywheel solid so that it cannot turn. Then you should be able to remove the nut on the pulley,........
Spiky's Avatar
Spiky
engine is fully back together, and running
pauls only suggesting was to lift car off ground and turn from underneath,
mmm or take it somewhere with a impack thing
Old 22-06-2004 | 08:54 AM
Spiky's Avatar
Spiky
cheers doug
Old 22-06-2004 | 08:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
impact wrench, that's the thing. either air or electric. you'll have trouble getting in the space though.
a shock is what it needs, rather than pure torque. if you can get a breaker bar on it and twat the welly bar with a fbh that should do it
Old 22-06-2004 | 08:58 AM
3drstretch's Avatar
3drstretch
Ooh it was my idea first why dont i get a cheers.
Old 22-06-2004 | 09:00 AM
foreigneRS's Avatar
foreigneRS
Testing the future
remember that it's a left hand thread so you've probably been turning it the wrong way
bullshitting you
Old 22-06-2004 | 09:07 AM
Disabled Account
If you cannot get an impact driver.....then try undoing the nut with the extra leverage that you would get from a torque wrench.........Or use a long bar extension tube thing.
All of this has to be done from under the car.....SO MAKE SURE THE CAR IS ON STURDY AXLE STANDS FIRST!!!
As the amount of leverage that you will be using could just slide the car off a jack......
Old 22-06-2004 | 09:09 AM
Spiky's Avatar
Spiky
stretch for you
yeah, paul has all the tools, we will do when he isn' so busy with his project
cheers for the advice,
though if anyone wants free drinks and wants to come and change it, ya more than welcome
Old 22-06-2004 | 09:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
not a good idea to use a torque wrench to undo stuck things. if the torque applied is too high it can easily send it out of calibration.
always use the proper tool for the job - in this case it's a breaker bar. halfords do a damn good long one for a good price.
Old 22-06-2004 | 10:04 AM
Mattie's Avatar
Mattie
and if that still doesn't work.
Use big breaker bar wedged against appropriate part of car (ie. chassis leg) and flick starter this always works.
Just don't let anyone stand too close though.
Old 22-06-2004 | 10:08 AM
Disabled Account
Mattie, are you sure about this??????????
Pistons will move up & down......SOME valves will be fully open (down)!!!!!!!!!
Old 22-06-2004 | 10:14 AM
Mattie's Avatar
Mattie
Doug,
Thought he had head off????
Old 22-06-2004 | 10:19 AM
Disabled Account
Mattie,
I do not think that the head is off at the moment..............
Old 22-06-2004 | 10:29 AM
Mattie's Avatar
Mattie
OK smart ass
Put belt back on and time her up, quick flick of starter, no chance of valve/piston contact.
Works for me anyway
Old 22-06-2004 | 10:33 AM
Spiky's Avatar
Spiky
i'm not liking the starter motor idea
Old 22-06-2004 | 10:43 AM
Mattie's Avatar
Mattie
Spiky,
As someone has already suggested, you need to shock the pulley bolt off (not just pure torque).
The starter motor trick would also be my last resort but it does tend to work when all else fails.
Old 22-06-2004 | 10:50 AM
Spiky's Avatar
Spiky
will see what happens when we next atepmt it
thanks for all the input guys
Old 22-06-2004 | 10:51 AM
Phil's Avatar
Phil
Jeebus
When you do get a puller on it, b careful where you put the puller arms (i.e. on the supports of the pulley) as SO many people (me included) have snapped the bottom pulley by not doing so!
Old 22-06-2004 | 12:30 PM
Neil S's Avatar
Neil S
Thats why I said to use a proper puller for the job Phil
As you say, someone (not me!!! ) snapped one of the CPS tabs on mine
There are 3 M8 holes around the pulley - theyre for a harmonic balance puller
Neil.
Old 22-06-2004 | 01:22 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Spiky, get a loooong breaker bar, rest it on the driver's side wing while the socket's in, put the car in reverse and turn her over... that'll get the nut off
Nah, seriously, lump hammer on breaker bar did it for me, pulled the pulley with a jobbie (harmonic balance puller) I got from local motorfactors, has three bolts that attach to the pulley. Soak it in WD40 the night before, came off like a dream - but that's not always the case apparently...
jonfoc
16
11-09-2018 05:35 PM
Dave_b
Ford Focus (All Models)
13-10-2015 05:48 PM
mark r
29-09-2015 07:27 PM
dombanks
21-09-2015 08:38 PM
dojj
28
11-09-2015 10:00 PM
Quick Reply: How do i get the bottom pulley off on my 2wd saff??
