SECS S8 software????
Old Jun 28, 2005 | 04:05 PM
Default SECS S8 software????
Ive not bothered to load mine off the disk yet, doh!
Will it run in windows mode on a laptop in a command shell window, or does it have to go full screen, and does it have pointing and clicking or is it all keyboard based?
Ive just bought a tft screen head unit that accepts VGA input so i was thinking i might be able to run the SECS software on the screen as gauges?
Old Jun 28, 2005 | 04:18 PM
Ryan's Avatar
Ryan
yes it will Chip, I've got it here and it runs fine on XP in a command shell.
It can go full screen or windowed.
Its all keyboard Based.
Simon said he's working on a New windows based version.
The DOS Based SECS software readings are as figure readings not guage style.
Hope this helps.
ryan
CraigN's Avatar
CraigN
doesnt have gauges on it from what ive seen
its all dos windowd and keyboard based too
Old Jun 28, 2005 | 04:19 PM
CraigN's Avatar
CraigN
ryan did u post my loom today ?
Old Jun 28, 2005 | 04:21 PM
Ryan's Avatar
Ryan
yes i did mate
Will be with you tommorrow before 1pm.
Will add it to your bill, or rather subtract it from mine
Old Jun 28, 2005 | 04:43 PM
Ah, fair enough, thanks for the info Ryan (havent forgotten your bits by the way!), doesnt matter now anyway as ive just decided im going to wire my wideband kit permenantly into the Sierra anyway, which means when im driving i can have RPM / BOOST / AFR / TPS displayed on the screen anyway, complete with a history logged in quite a lot of detail.
So when the mrs borrows the car i can play back her journeys and see if she has been on boost much, LOL
You can even configure alarms to play a WAV file through the car stereo (well laptop in my case) when certain situations occur.
So i can have it shout "AAAARRRRRGGGGGGG" at me when i go lean if i want.
Or when the mrs is driving i can make it play my voice shout "give it some fucking stick bird" every time she comes off boost, PMSL
Ace little project it should be setting it all up
Old Jun 28, 2005 | 04:47 PM
Ryan's Avatar
Ryan
Cool, cheers chip
Old Jun 29, 2005 | 12:54 PM
foreigneRS's Avatar
foreigneRS
Testing the future
chip, i've taken the output from the tewb unit and read it into excel using some vba code. the various values are then displayed as graphs, configured to look like gauges. i've also included the output from a 4 channel thermocouple reader that is connected to thermocouples in each exhaust port to measure egt. have a look at this, and tell me what you think:
this is a slightly old version, the newer one has scaling on each gauge, but it's on another pc.
Old Jun 29, 2005 | 12:57 PM
Looks ok to me mate, it is in real time though?
Old Jun 29, 2005 | 03:47 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yes it's in real time. has peak hold for each gauge, and peak high and low for lambda
Old Jun 29, 2005 | 03:48 PM
Interesting stuff, how did you get excel to actually read the serial port in the first place though?
Old Jun 29, 2005 | 03:53 PM
ECU Monitor Enthusiast
YUM360,
Feck off and brake another limb
chip-3door,
I have windows software for the S8 that is being tested before release.
This does have logging and configurable graphical gauges.
Will show it to you at the next weston meet this weekend or whenever I see you next.
Old Jun 29, 2005 | 03:58 PM
Thats a point what happened to you last week, one minute you are posting a thread getting people to go and join you, and the next im sat in pizza hut wondering where you are
Untested software is fine by me mate, its only a display after all.
Is there an SDK released for the SECS?
Old Jun 29, 2005 | 04:02 PM
Sorry mate. Was going to go but my crank pulley was playing up and the car would not run properly.
Fixed now though.
Yes I have 3 pieces of software you can have a look at....
1) Windows version ecu programmer
2) Graphical data display and logger (built in to item 1 too)
3) Win SDK - DDE / OLE server comms software to allow other packages to read the data comms. E.G excel/powerpoint, VB etc....
Old Jun 29, 2005 | 04:08 PM
oh, nice one
Makes more sense than using the wideband kit then as thats got its only display anyway for the lambda and the rest is all in the SECS anyway, ie boost, TPS, rpm etc.
Is there any logging software?
Does the SECS accept a wideband input from a wideband controller?
Old Jun 29, 2005 | 04:10 PM
oh, nice one
The next ECU software upgrade includes wideband control and/or display as well as ALS.
Old Jun 29, 2005 | 04:13 PM
Includes wideband control, as in just need a sensor and no external controller you mean? AWESOME!
When is next version of software likely to be available?
Old Jun 29, 2005 | 04:21 PM
chip-3door,
I have been running the new version in my car now for the last 3 weeks to thorougly test it before release.
I will let you have a sneak preview soon.
The ecu manufacturing/sales business is about to be taken over by "others" leaving me to concentrate on the development work.
Once this take over is complete, the official release will happen.
This should all happen within the next 2 weeks.
The wide bandband can accept a voltage signal from an external controller
or will require an external interface costing around Ł30
Old Jun 29, 2005 | 04:24 PM
Ah fair enough, i will just use my existing controller then mate.
Partial takeover sounds good mate, i really hope it works out for you, you certainly deserve some decent income from such a fantastic bit of kit.
Old Jun 29, 2005 | 04:27 PM
PS
for the antilag, im just going to put a second ICV in the car (larger diameter vauxhall one) plumbed in after the throttle plate, and then when the dashboard switch is flicked to tell the ecu to go into antilag, i will get it to also open a relay to fire the valve and keep it open till the switch turns off.
Old Jun 29, 2005 | 04:56 PM
Oi dave, PM me those hotel details you clumsy freak
Old Jun 30, 2005 | 12:14 AM
Eagle's Avatar
Eagle
Super Moderator
so does that mean the prices will go up if others are selling it??
Old Jun 30, 2005 | 05:13 AM
space hoppers's Avatar
space hoppers
simon just ask yum how his gearbox is doing that will touch a raw nerve ha ha
Old Jun 30, 2005 | 10:46 AM
foreigneRS's Avatar
foreigneRS
Testing the future
SECS, all sounds good matey. keep the developments coming
chip-3door, it's very easy to get excel to read the serial port, just a few lines of code in Visual Basic for Applications (included as part of excel).
Old Jun 30, 2005 | 10:52 AM
Nick, didnt realise VBA could see the serial port so easily, thats good stuff
jay030787
Sep 25, 2015 01:38 AM
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
