View Poll Results: left or right
Voters: 11. You may not vote on this poll
power steering pumps
I hope you did manage to get some sleep!! But your face was such a picture as we kept looking under the bonnets!!
So now we have more or less worked out it must be because of air con which was removed.... does that mean your dashboard is not standard and has been changed then???
0-60 in 17 seconds (eek)
Sorry pete, it just looked different to every other sapph I'd seen, that's all
So, it's approx 66% right and 33% left, but I am still not sure why there is a difference.
MrsFrog's 2wd is an E plate and pump is on the right side (inlet)
Eagle's 4x4 is a H plate and pump is on the left side (under turbo)
My 4x4 is a J plate and pump is on the right side (inlet)
Both eagle and my blocks are 200's.
Doesn't make sense Mind you, there's probably a very good explanation but my head is full of cotton this morning
U kow what chip I almost almost came down on sunday! i was drivin around & couldnt find any1 called dan he said we down weston i was like hhhmm shall i go!
ANyway i ended up in the pub! where i spent the night in the company of 2 lovely ladies!
Or does that just happen to me?
goood point!
but im tryin to actually go out with 1 of the ladies!
i need to convince her IM not a slut!
Just point at your head and say "with these looks do you REALLY believe i ever actually get laid?"
That line may work for your chipper but when your as handsome as me there is no chance of her believing it! plus her best m8 used to go out with my old room m8 so she tended to see me bringin back a different bird every ngiht i went out!
Sure ht e boys will vouch for the quality of ladies Im seen with!
& Im sure a few of em have school photo day comin up soon so will send u the pics!
Knew u would like that!
But judging by the crying, begging and screaming and the fact she was shaking uncontrollably, i was wrong
Originally Posted by nightdavva
as a rule all aircon cars have p/s pump on the left(turbo side)and non aircon cars on the right(inlet side),but i believe late 4x4 sierras and escorts without aircon also had em on the left..................Dont quote me though...
Trust ford to do things properly
Did you know that the starter motor (more anoraky stuff for you) for a 4x4 cossie comes with two different gearbox mating faces, and both have exactly the same part numbers, etc...
