Where can i buy a jetted amal valve?
you buy an amal valve (which youve probably already got one) and you buy some carb jets from the motorfactors for about 10p each ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
then you just need to understand the fundementals behind boost control and bleed valve, so best just to get it done by a pro imho (mistakes can be fatal to the engine)
AMAL valve is apparently a ford only item so you will have to get one from there if you need a new one
CheeRS
Phil
P.s they arent cheap
they are 47 quid from Fords.
Wish i hadnt of run over mine pushing my car out the garrage
phil, an amal valve IS a bleedvalve you tit
what the fook was it doing on the floor if you were pushing your car out the garage?
I 'thought'
[quote="CabrioTurbo"][quote]
[quote]
Can be found on many Saab Turbo, perhaps cheaper as well but dunno if the jet size is the same.
/Andreas
[quote]
/Andreas
As I remember it ;
Drill a 3 mm hole in the airbox takeoff, and in the jet located in the takeoff on the amal valve that goes to the air box.
The hole in the air box on my saff was almost 3 mm (maybe somebody had played with it)
When I tried to bore the jet in the amal valve to 3 mm the jet came out of the amal vale ( talking about the takeoff that connects via a hose to the airbox).
So I ended up putting the hose back on without the jet ......
It helped hesetation a bit!
Now I have an amal valve jet in my ashtry![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
Cheers Kennert
Cheers Kennert
[quote="Andreas"][quote="CabrioTurbo"][quote]
/Andreas
Indeed! the Saab one is identical in operation, but only has one jet fitted in the compressor connection stub - take the jets out of your existing one and fit in the replacement. The Saab valve has a much better connector than the Ford one, moulded into the top of the valve, so won't suffer from the terminals going loose and breaking the internal connections, which is what happens with the ford one..
The Saab part has a number on - 7517477 - if that's any help.
/Andreas
