Cooling problem on S2!
Took both the RS's to the FordSport meet last night and the drive home was shall we say a spirited one .
When I pulled up on my drive the temp guage was very very high which worried me so I opened the bonnet and left it running. I noticed the header tank was puffed up like a balloon and when I squeezed the top rad hose it felt really hard. Thinking I may have a problem now
I know the heater matrix isn't great so I was going to bypass it. Any suggestions on things to try/check appreciated
Monitor this closely until u find the problem!
I had similar on mine and I blew it up in the end.
I never found the problem but I think it may have been a blocked rad.
the header tanks do expand with the heat and pressure, its only if it splits that it becomes a problem,.
Have you replaced the header tank pressure cap ? Think its only Ł7 from ford. If its not working properly then the excess pressure wont be released from the header tank.
is the water and anti-freeze the correct mix of 50/50 ?
Did the fans cut in and cut back out again? If so could be a faulty temp sender giving a false high reading
The cap was changed for a new one just before my feature last summer. All's been well until last night . Bit worried as I've invested too much money in this car to kill it.
Think I'll knock off work at 4:00 and take it to bits. Worried about it now
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
