Well it didn't start! need help please!
Monte Geek
Need the help of the PF peeps again!
As per thread https://passionford.com/forum/viewtopic.php?t=128255
Got up to step 4 but the engine wouldn't crank. The starter motor made a loud click then nothing
What do I do?? What up??
Monte Geek
Thinking about it the battery has been moved to the inside of the car and the earth strip is bolted to the chassis could it be the earth isn't that great?
What cable are you running and is the engine & gearbox grounded properly ?
Can you measure the voltage on the starter to see what it drops to on cranking (or clicking)
To prove the starter is okay remove it and wire it up manually with some hefty jump leads see if it spins and the solonoid is working okay.
Monte Geek
Right think I've sorted it... THINK!
I bought a new Red Top 40 tested all my earths, checked the wiring and a load of other things.
Finally followed NUTS RuS advise and took it off and tesed it with my power pack and the solinoid was poping out (hense the click) but it wasn't spinning
So much for a fucking recon starter.
So where's the best place to get another Starter? do Ford bend you over for them?
Monte Geek
Yeah put the plus on the two larger connectors and then the minus on the small ground, sparked like a beaut and the solinoid shot out but din't spin
Take it to somewhere like these for testing or repair, its where some motor factors and the trade would get theirs.
http://www.unit-exchange.co.uk/index.html
Dont know this place but I use a similar company local to me.
Monte Geek
Yes mate Car spares Delamare Rd was my first thought to use them, but everythink electrical I've ever bought has broke
At least I have a warrenty so fuck it, probably get a quote from Fraud first
Monte Geek
Right still at it!
Got another starter today, discovered some of the wiring was missing
Right I'm at the stage where as the wiring is sorted and tested, the starter is tested and working and so is the battery...phew!
When turning the the engine over it clicks and spins slightly, then stops, then spins slighty then stops and so on. Is this progress??
Stuck the battery on charge and will try again in the morning.
Any thing else I should be doing.
As an observation each time the the engine turns slighty the power wires move! is that right???
It Wasnt Me!
power wires move when engine turns slightly?
shouldnt do? lol
whack the starter a good un when its trying to turn, and also as said battery sounds drained now!
Hope im not too late - but those type of batterys only like a small trickle charge over a longish time period. Dont try and boost it - you will knacker it up.
Whip the plugs out - and then try spinning it over does it turn with ease ? If not then maybe you have an earthing problem on the engine or gearbox.
Adam Graham
06-09-2015 06:04 AM
