What member of PF.com runs the most boost?
Old 20-06-2005, 08:12 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Default What member of PF.com runs the most boost?
Mine is only an ickle engine and runs a MAX of 25psi
Whats your max boost level that you run either on road or track etc..
Old 20-06-2005, 08:15 AM
THE RS DJ
THE RS DJ's Avatar
What a strange question.....
What did people have for dinner last night then........
Old 20-06-2005, 08:19 AM
Oranoco
Oranoco's Avatar
25psi for my S2 Slightly more than the standard 7psi
Old 20-06-2005, 08:20 AM
Versus_Creations
Ask me a question!
How is that strange? Just a question..... Im sure worst questions have been asked mate.
Intrested in what engines and setups run accross the country in terms of boost.
Old 20-06-2005, 08:50 AM
zvhturbo
zvhturbo's Avatar
280 KPA
Will go up soon though.
Old 20-06-2005, 08:59 AM
GARETH T
GARETH T's Avatar
34 psi,,, when my air injectors failed
Old 20-06-2005, 09:52 AM
Phil
Jeebus
Phil's Avatar
I used to run something like 37psi
Old 20-06-2005, 09:57 AM
NUTS RuS
NUTS RuS's Avatar
Old 20-06-2005, 10:03 AM
zvhturbo
zvhturbo's Avatar
Originally Posted by NUTS RuS
-14 on idle
Old 21-06-2005, 12:54 AM
NUTS RuS
NUTS RuS's Avatar
-14.5 actually
Old 21-06-2005, 12:55 AM
MK5RST
MK5RST's Avatar
7 psi
Old 21-06-2005, 12:57 AM
rs_daz
rs_daz's Avatar
23psi peak
Old 21-06-2005, 12:58 AM
safflad
safflad's Avatar
had mine dyno'd at weekend 29.6 psi
Old 21-06-2005, 05:51 AM
Ran 2.7bar, just over 40psi in my old conversion but Neil at Carwise runs 2.8bar in his Saff think thats about 42psi.
Rod
Old 21-06-2005, 05:54 AM
Nath
Nath's Avatar
Mines about 4psi as its a right old shed
Old 21-06-2005, 06:08 AM
gus
gus's Avatar
use to run 30lb
dont think i will run that much in me new engine
well not all the time anyway
Old 21-06-2005, 07:08 AM
gurnE
gurnE's Avatar
I ran 32psi on the saff
Old 21-06-2005, 07:33 AM
Nutter
Old 21-06-2005, 08:06 AM
Rab
Fucking superstar........
Rab's Avatar
6psi
Old 21-06-2005, 08:31 AM
Dan
Dan's Avatar
Rod beat me too it, was gonna say Neil @ Carwise!
Mine is nil, is N/A!
Old 21-06-2005, 12:05 PM
Snowy_Astra
Snowy_Astra's Avatar
looking to run 12 on my supercharger
Old 21-06-2005, 12:07 PM
Matt
Matt's Avatar
peak 38
held 32 backing down to 30 at 7k
Old 21-06-2005, 11:21 PM
TiB
TiB's Avatar
39psi tailing off to about 32psi,
Old 21-06-2005, 11:34 PM
xr-stu
xr-stu's Avatar
Originally Posted by gus
use to run 30lb
only when the turbo spools up eh?!
no boost for me
want an xr2 turbo before the years up!
Old 21-06-2005, 11:35 PM
Versus_Creations
Ask me a question!
Great stuff,
Any videos of the engines that are running high boost
Old 22-06-2005, 07:04 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Mine was mapped for 32psi, but we didnt really run it beyond 28psi.
Old 22-06-2005, 07:05 AM
Christian and Beccy
#1 in Spelling Club
Out of interest, are Turbo's still efficient at these high boost levels?
Old 22-06-2005, 07:12 AM
Lee @ Fusion
Lee @ Fusion's Avatar
20psi max for me , if fueling allows without a remap im gonna tweek it slightly
Niel @ carwise is deffo the Big Boss of Boost
Old 22-06-2005, 07:14 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
26 psi, but im getting bored fo it now
Old 22-06-2005, 07:22 AM
GARETH T
GARETH T's Avatar
depends what turbo's, a t4 isnt really the right turbo for a 500 hp yb
Old 22-06-2005, 07:32 AM
Paul Eggleton
Paul Eggleton's Avatar
Following on from what Gareth said, if you look at a compressor map for a turbo, the 'island' in the middle is meant to be the area of highest efficiency. So depending on the turbo, it will depend if the boost pressure you are looking at is in or close to the island. The further away you move the less efficient it becomes.
I would imagine as a very general rule of thumb, if you use bigger and bigger turbos the pressure for optimum efficiency gets higher, coz that is why they are big so they can work at higher boosts and air flow efficiently.
Old 22-06-2005, 07:35 AM
GARETH T
GARETH T's Avatar
Paul Eggleton, i plotted a 500yb figures onto a compressor map once, and they are far far from ideal
Old 22-06-2005, 08:11 AM
wimwerf
wimwerf's Avatar
what is an ideal turbo gareth t...gt30..gt35..
Old 22-06-2005, 10:19 AM
GARETH T
GARETH T's Avatar
i dont kjnow to be honest,,, i didnt look into it that much
when spec'ing a turbo for an application you can do all the calculations you want and platting on different compressor maps but the only true way of spec'ing a turbo is trial and error
Old 22-06-2005, 10:34 AM
Lou Lou.
Lou Lou.'s Avatar
was 14 not sure wot it will be when its finished
hopefully will find out very soon
Old 22-06-2005, 11:34 AM
james_birch
james_birch's Avatar
was ment to be 17psi.......but had an air leak and was 24psi...then turbo shat its internals out and is now turned down to 15psi till i get it set up again! in which im hopeing for around 18/20 on std compression too
Old 22-06-2005, 11:39 AM
Ryan
Ryan's Avatar
Here's my compressor map
Old 22-06-2005, 11:40 AM
GARETH T
GARETH T's Avatar
thats intresting ryan,....
Old 22-06-2005, 11:41 AM
RANJ
RANJ's Avatar
carwise saff
mega boost needed to make power
Old 22-06-2005, 11:42 AM
Ryan
Ryan's Avatar
so what would say is the optimum BHP\flow of this turbo looking at the map
Quick Reply: What member of PF.com runs the most boost?
