SQUUUUEEEKKK (help! lol) UPdated
hi all
any ideas would be great
my car has suddebly developed a really loud squeel
when your going along (between about 2,000 rpm and about 3500)
sounds like when a fan belt is slipping on a car, but Really high pitched
and sounds a Little bit metallic...
The noise also dissapears when the clutch is pressed...
any ideas?? clutch release bearing??
any ideas would be great!
thanks!
thanks!
fook it engine out and re-con that at the same time..
400 bhp here we go.
anyone else any ideas on it? i dont think it would be anything else TBH
400 bhp here we go.
Re: SQUUUUEEEKKK (help! lol)
Originally Posted by pee vee
hi all
thanks!
thanks!
Front propshaft universal joint turned out to be the cause (engine end), take the engine splash guard off and give the front prop a wiggle, any movement and the bearings are fooked. It took me ages to find the cause as it almost sounded like an air leak.
Mark
Yep same thing was happening to mine, cept it did it at Idle.
Look here to see the dangers of running a fooked release bearing
https://passionford.com/forum/viewtopic.php?t=127983
hi all
thanks!
thanks!
Mark
think you might be onto something there
the car dont do it in neutral.
it ONLY does it when accerating. as soon as you let off the gas
it stops, OR as soon as you press the clutch it stops..
so i guess the load being transmitted thru the shaft might do it?
i will have a look tomorrow thanks mate!
MADMAC! thanks for your input too! it could well be realease bearing
but strange that it only does it in gear
Mine would only do it at light throttle whilst driving, drove me bananas
New UJ is easy enough to get hold of and not too hard a job to fit.
I had to drop the front ARB as well as the exhaust to enable access to the front prop. I used to have a very slight vibration during acceleration and that has totally gone after fitting new UJ
Mark
Mark
Eventually the clutch stopped releasing properly and it was a nightmare to get in any gear.
Mark
Mark
lol
sound like the same thing! wicked, i'll have a blast with that tomorrow mate
bang same sound at same time on mine
i even took the turbo off to check the exhaust wheel hadnt been catching the housing - was fine
im still not ruling out a blown inlet to head gasket or plenum cover gasket
Checked Front prop today,, wadda ya know!
loose as you like! a good bit of play there! so i guess its that.
any one got a front Prop they wanna sell
The prop only needs a new UJ which is around £20
I just fitted a new UJ and the problem was solved
Mark
Mark
brill mate! you get it from ford?
last few bits i asked for 4x4 saph from ford they told me they dont make
any more!! (Lower arms! lol)
Mark
Mark
I got mine for Agrispares/Southwest Bearings at Bowerhill - was abot £18 from memory.. it would be helpful if i could remember the size specification for you wouldn't it....
