cosworth head tools help needed please
i need a 3 cosworth tools anyone advise where to get them
valve stem oil seal installer(exhaust)
same as above but for inlet
valve stem oil seal remover
any help will be much appreciated
Testing the future
you can use a socket to install the valve stem seals, i think it's about 7mm and 8mm, but check that it's a good fit before using it. you need a deep one as well.
removing them is a pig. there are special pliers available from tool shops, but they're not very successful. you could always se a small screwdriver to split the metal surround and peel it off, but be careful not to damage the guide or the head.
like Nick says - use a sharp screwdriver to cut through the side of the thin metal shell of the old seals. Once split, the seal will easily come away from the guide.
They are otherwise very tight when they have been on for a while, and all but impossible to pull off.
To install new ones, use a deep socket of a suitable size to be a good fit onto the top of the seal body, put a spot of grease inside the seal and tap it gently onto the guide.
cossiecrew - concentrate on getting them off... putting new ones back on is a piece of piss, they just push on with a suitably sized "tube" to push them on with..
Originally Posted by daz1968
If you are having new guides they come off when guides are pressed out, thats how mine were removed
big_Rad
15-09-2017 09:36 AM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
