Converting MFI ERST to EFI...?
ok ok, i might be getting a RST on sat
and i want chatter not a fookin gay d/v like its got and you cant get it with mfi cos of the air flow meter.
i got me a SECS S8 so management no probs.
so is it just a case of an adaptor plate for the fez turbo efi inlet and some injectors, and additonal wiring??
any help appreciated
just finding my feet
THERES A FEW ways to do it
ya need either a efi flywheel and convert the block or a 1.8 bottom pully for the cps
you can also convert the mfi engine to efi as tbh i found getting all the addaptor plates and the 1.8 pullys and machinging fooking long
bit of maths and ya sorted in 2 days
if ya choose to be brave om me and ill show ya
its not that hard Christian. I know its not a simple case of plugging everything in, but it seriously doesnt take that long if you know what your doing.
is there any real point to you going EFI though? or is it purely so you can use the ECU?
I wouldnt bother going EFI personally.
Unless you doing a high spec build.
You guys make it sound like its one of those jobs you start after tea and have finished by Bed time
thats only cause i got to take the engine out and drill the block, apart from that the loom is piss and ripping to old crap out aint hard either
if anyone want to take me up on the challenge feel free and me and cowboi will do it over a weekend and get it running
now we got air tools and a proper block and tackle recon it might be quicker too
aslong as ya get a list of parts together and got a decent person to help then its easy
oh a serious note if ya want ill make another template for ya and post it for when ya drill the block as thats sooooo much easier and a better option than a 1.8 pully imo
OK, one question, Ive heard that OFAB is more tunable, or you can run more boost with it, that OFAC? Is this true or is OFAC ok to use, and can be converted anyway? I know u need ecu and map from same thing i.e ofab or ofac etc...
ofac has a 2.5 bar mapsensor and cant see boost after that, its not a normal mapsensor either so theres no add on ya can have, stu,,,, ok kenny@MSD can map ofac anyway and is a god with it
ofab has a normal 2 bar as standard which is the same as a cossie, you can add a 3bar mapsensor to it and allow the ecu to see 2 bar of boost ( where the ofac can only see 1.5bar)
if ya got a ofac loom, it can be converted easy and ive done it a few times and sorted all the teething issues
ive bought a ofac beige chip from msd and that was for 15psi and then check the fueling and then i converted the car to ofab and got a ofab beige chip ( sold the ofac chip with the ecu/mapsensor and converted that car to ofac) the ecu is easy, the easiest conversion is ofac as ya can get a xr2i loom and then all ya need is the map sensor as the plug is the same and ecu, then ya swop a few pins
ofab on a xr2i looms is swopping a few pins and also getting a ofab ecu and changing to a 3 bar mapsensor but ya also need the loom plug too and also theres a supressor ya need aswell which makes it a git as fords no longer stock the supressor, not sure if it works with out as theres mixed feelings on that subject
if ya running a beige converted frst and want no more than 15psi then ya aint gonna have a issue with either option
any more advice then just PM me as the efi conversion i dont before had a right git of a think on it and then we found the supressor was still in the loom and that makes a ofac car hit 3k then cut the ignition , took me a week to sort that problem
Cheers ginge, I have a complete xr3i EFI loom, but guess that will be no good if I used a frst ecu and map etc on it? Ideally would be to get a whole frst setup, just wonderd if I shouldopt for ofac or ofab
Mc5506
05-10-2015 09:57 PM
