Water Wetter etc
rick you should of said you fancied some at tatton they had it for a tenner a bottle instead of burton's 20 quid
ebay sometimes has some for around a tenner tho anyways
matt
matt
Originally Posted by Andreas
Mixed with normal coolant fluid and water it does feck all on my car so dont bother unless you mix it with just water.
Works a treat, minis use it due to their crappy side mounted radiator!
is this the stuff
Red Line WATER WETTER Super Coolant
Helps Control Overheating
Doubles the wetting ability of water
Run up to 20 degrees cooler
Great for Cars, Trucks, Motorcycles, RVs, ATVs & Snowmobiles
Use with all Water-Cooled Engines
Also provides corrosion protection for modern cast iron, aluminium and brass systems
Cleans and lubricates water pump seals
Can be used with distilled or tap water
355ml - 12 Fluid Ounces
Price includes VAT
Price includes VAT
i use it in mine, with antifreeze, does run a bit cooler, tends to cool down quicker when the fans kick in
put then mine never goes above half on the gauge
Didnt really notice much diff on my car as she runs very cool any way with big ally Rad! But did notice that once it gets warm it cools down a lot quicker once moving agian!
Mark RS
12-10-2015 06:01 AM
