restoration
restoration
sorry mods if its in the wrong place but i need an answer before i top my self
help please from all the resto people. i am in the middle of a full restoration of my car and while i have been trying to paint the under side every so often a patch appears of what looks like an oily surface..i have tried using petrol to clean area but to no avail.please help with offers of what i can do.
what u got i think is sections of steel inpregnated with oil over the years. steel is porous & will hold old oil in it rather like a sponge. u need to clean these areas thoroughly with a degreaser & let dry. will probably take a few attempts to shift it depebding on the age of the car. hope this helps
thanks for the help.
i dont know if this is a contributing factor but the under side is coated in what looks like gritty black undersel which is sticky which suggests it was done not so long ago how can i get rid of this
mates dad has been doing the same work on the underside of a mk 2 escort. used a small blow torch (taymar type ) & a chisel & scraped the lot off. takes ages. dont use too much heat to redden metal, just enough to melt the black crap & make it easier to scrape off. what sort of motor is it? & what age?
its a j reg nissan pulsar gtir and it has been took back to bare shell.its had a colour change full quaife box built for it etc and is getting fully rebuilt engine,diffs etc
the under side is the only place i was going to leave but now decided i might as well do it seeing as the rest of the car will be factory fresh.
i remember seeing the blck gritty stuff somewhere before.looed like a cheap version of waxoyl.
sounds like stuff we used to use called tetroysyl, was a gritty crap u brushed on after repairs. not worth the full of yer arse with roasted snow. a little heat should shift it
u need to remove all the underseal from everywhere. Clean the underside so u can eat ur dinner off it. Then before you paint you need to wipe it down a few times with pre paint(panel wipe).
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
