oil leaks
just finding my feet
oil leaks on a cossie,,,,,,,,,,, never
mine leaks soo much oil that when i polished all me tanks i started the car and it flung oil all over the fooking tanks spend 2 days polishing
0-60 in 17 seconds (eek)
I've had an oil leak (amongst many) near the front of the engine (just above the dizzy), build up on the head gasket in the corner allowed oil to seep out. Glad I got that sorted before I went really bad.
Remember, oil stops your car rusting, so it's good to have a few leaks
the floor honestly anit got any rust,, its COVERED in oul though, so much that when it rains and i park the car it drips rainbow dots
im not kidding either
cleaned me manifold today to find its polished
Favourite places for oil leakage on Cossie engines:-
Cam seals
Cam cover gasket / half moon seals
Front crank seal
Dizzy seal
Oil pressure sender block
Turbo oil feed unions
Turbo oil drain pipe
Poorly fitted breather kits
Sump gasket
Rear crank oil seal
etc etc..........
Cam seals
Front crank seal
Dizzy seal
Sump gasket
Rear crank oil seal
etc etc..........
Originally Posted by b19bal
spadge ya could have said any part of the engine
dont forget theres 2 front oil seals to leak aswell
both of mine are leaking and the dizzy and also the sump, the rocker cover aint but judging by the tapets thats cause theres no oil getting that high up
bottom pully and aux pully, why is there more i got that are leakign too
from what i could find out ( im not trying to explain tp you nit wanting to be corrected on what im wrong) theres 3 main oil seals, 2 on front and 1 on rear
the rest are gaskets
well except for the half moon on cams and the other thingys that seals the sump wound the crank ends on the block
deathrider666
28-09-2015 06:12 PM
