Noisy tappet advice
Noisy tappet advice
As title,1 or 2 are quite noisy for first 2-3 miles then usually quieten down to almost nothing,then sometimes come noisy again/go quiet. Getting on my tits actually,would it be worth the hassle to change them or put up with it? Is it likely to cause any other problems? Cheers.
I'm wondering the very same thing... One of my tappets gets noisy from startup occasionally. There doesnt seem to be any rhyme or reason to it, it just does it lol
If it was all of the lifters, I guess it could be a sign of low oil pressure like
Neil.
Neil.
Could be right mate
Think the actual explanation is that the non-return valves in the tappets go and allow the oil to drain from them, hence when u fire it up from cold, pressure has to build up in order to 'inflate' the tappets to take up the gap between the valve stem and cam lobe....
Neil.
Neil.
noise
A set of new ones is the only cure if you are fairly sure you have good oil press. There is a geek on ebay sells brand new sets for Ł100 and I think they are oe ones.
Originally Posted by plynchy
Had a rebuild 10k ago! Oil press. is apprx 45-50 psi when driving
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
