Lost boost!!!
Old May 29, 2005 | 10:10 PM
rsjohn's Avatar
rsjohn
Default Lost boost!!!
Iv recently fitted a new engine and turbo into my 4x4 sapphire cosworth.
It was a running dark greens T3 and 24psi of boost before the change.
Iv now fitted low comp engine, with BD14 cams, T34 with .63 housing and converted to 2wd exhaust manifold.
The problem im now having is i cant get it to boost properly and only does 15psi max at high revs.
I have swapped actuators and adjusted them, disconnected amal valve, checked for air leaks.
Any one have any idea what it could be????
john
Old May 29, 2005 | 10:24 PM
Bamber's Avatar
Bamber
have you had it remapped mate stu at msd did mine he the man
Old May 30, 2005 | 09:09 AM
rsjohn's Avatar
rsjohn
Yes i got a chip to go with engine spec as running different injectors.
Iv also fitted a bailey breather stsyem, this wouldnt have anything to do with it??
john.
Old May 30, 2005 | 09:19 AM
Graceland's Avatar
Graceland
Team HOTHOT!
have you checked its getting full throttle? had this on mine and stu sorted it for me
Old May 30, 2005 | 10:37 PM
rsjohn's Avatar
rsjohn
Yes getting full throttle according to secs monitor.
When put foot down boost gauge goes to 0 but wont start boosting til 4000rpm and max boost is 15psi at rev limit, it should be boosting earlier and to 30psi.
Because i have now fitted T34 turbo will i need to adjust the jets in amal valve?? If so would this cause it not to boost properly???
john
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
Russ Payne
Sep 25, 2015 08:29 PM
