Pectal baby (daughter) board info Req IE running Anti Lag
29-05-2005, 09:27 PM
Hi I have the chance to buy a series 1 Pectal baby board but Iam not sure if it is capable of running Anti lag
My mate thinks you need a series 2 board and above to run it.
does anyone know for sure as I don't want to waste my money.
cheers Dave.
30-05-2005, 08:41 AM
up
30-05-2005, 11:43 AM
PectEl has no A in it Dave!
Sorry mate. Can't help you cos we threw the Pectel board away from my Dad's car. That was an issue 3 board.
30-05-2005, 11:53 AM
The board is ONLY a key.
It depends ONLY on the chip type fitted !!!
You need to talk to a PECTEL approved software supplier for exact details before making any purchase.
30-05-2005, 12:27 PM
the board is not required to run antilag - only required to run pectel software protected by pectels own keys
30-05-2005, 01:03 PM
Ask me a question!
An MTC board will run ALS + all the other trick stuff with a Decent map
30-05-2005, 01:06 PM
Jano_OddKidd , Excuse my ignornace, what is an MTC board ?
30-05-2005, 01:10 PM
Quote:
me too ?????
30-05-2005, 01:12 PM
Ask me a question!
No problem
Its type of board Simon. Another version of the Pectel board or Collins etc...
HTH
Regards
Jano
30-05-2005, 01:18 PM
Jano_OddKidd , Thanks for that.
I know exactly what you mean now - just never heard it called that before.
30-05-2005, 01:59 PM
and it still isnt needed !
31-05-2005, 08:17 AM
Markk are you saying you can run it of a normal P8?
Dave.
31-05-2005, 09:47 AM
up
31-05-2005, 09:49 AM
Quote:
Dave.
I think this is the case, not 100% sure though.
31-05-2005, 01:49 PM
up for a tech bod cause I don't want to pay Ł300 for a baby board if Idon't need too.
Dave.
31-05-2005, 04:21 PM
yes , P8 is the only weber ecu that can run als without a board ( bear in mind the board is only for ecryption-but if i was to sell you a chip with als on it I wouold encrypt it also
hence why you have to pay for boards) - mainly due to its ability to its timing functions after and before (
) TDC
31-05-2005, 06:55 PM
So Iam going to have too splash the money out
Dave
31-05-2005, 08:39 PM
But you don't need the board!
31-05-2005, 08:45 PM
Quote:
DazC ,
but you cant get the software without the board
31-05-2005, 09:06 PM
Quote:
Originally Posted by markk
Quote:
DazC ,
But a P8 doesn't need the board though does it?
31-05-2005, 09:25 PM
Quote:
Originally Posted by DazC
Quote:
DazC ,
31-05-2005, 09:36 PM
Ask me a question!
Round and Round and Round
The bottom line is if you want ALS buy the board, or find the software and keys
an ALS board is not that much new
i would rather have a new one that has done 0 miles compared to a second hand one out of a Rally car with years or use and abuse
31-05-2005, 09:38 PM
PassionFords Creator
Quote:
Jano_OddKidd ,
No such thing as an "ALS BOARD"
Roflol.. round and round we go...
31-05-2005, 09:41 PM
Quote:
Originally Posted by Stu @ M Developments
Quote:
Jano_OddKidd ,
31-05-2005, 09:58 PM
Ask me a question!
Quote:
Jano_OddKidd ,
OKay..... A PECTEL BOARD that can run ALS then
31-05-2005, 10:25 PM
Quote:
Jano_OddKidd ,
doesnt have to be pectel either
31-05-2005, 10:28 PM
Ask me a question!
01-06-2005, 06:34 AM
Quote:
Jano_OddKidd ,
how about a monopoly board.........round and round we go
01-06-2005, 04:25 PM
How many degrees ofter TCD is the ignition for antilag?
Wondering if it is possible using edis.
Thanks
Darren
01-06-2005, 04:55 PM
01-06-2005, 05:17 PM
turbodisplay ,
You can only go about 10 degrees after TDC on a 4 cyl EDIS module.
Not quite enough for backfires let alone ALS
01-06-2005, 08:03 PM
turbodisplay ,
01-06-2005, 08:17 PM
How come i paid alot of money for a collins als board and chip?
Need'nt i have bothered for my p8?
01-06-2005, 08:30 PM
re-read the post - the board is there for software encryption, the P8 cant do anything without software !
01-06-2005, 08:33 PM
so would a normal pectel board work?
01-06-2005, 08:36 PM
as long as the software was included on the chip that is on the board, basically you cant get the software for free, you need to buy it encrypted and to do this you need the pectel board to allow the encrypted software to work.
01-06-2005, 09:09 PM
I did a miniature essay on these boards recently, but i forget what topic it was on...........
01-06-2005, 11:05 PM
Yeah, i know it is limited to +10 degrees on edis, however if the reference point of tdc for cylinder 1 was relocated by 10 - 20 degrees the efective range can now be -40 to +30.
Only problem is that limp home mode will now be +10 TDC instead of - 10.
So the question is, will 30 degrees atdc be good enough?
Darren
02-06-2005, 12:06 AM
Ask me a question!
02-06-2005, 12:08 AM
Ask me a question!
Darren that is a great idea tho
Just need to figure out what effects it has on other areas of the map?? If what you said can be done.
