Secs S8 ecu and wb lambda sensors
Hi,
does the S8 ecu really drive wideband lambda sensors directly or does it need some wideband lambda driver between the sensor and S8 ecu? It does say on the secs website that it has closed loop wideband Lambda sensor control but what does this really mean? Simon can you explain or anyone else who nows?
Testing the future
afaik, it doesn't drive a wb o2. it can accept an input from a controller though, for closed loop running. of course it accepts the 0-1V signal that a nb sensor will output, and most wb controllers can output a simulated nb output. beter is if it can accept a 0-5v input for wb, but i don't know off the top of my head
Hmm, that's what I also tought but I got reply from Mike Rainbird that it would drive the sensor directly. Maybe he misunderstood my question, because of my bad english writing
FYI...
The S8 is FULLY narrow band compatiable as it is.
The next software release will include FULL wideband support including AUTOTUNE.
(and ALS for those who are interested)
This will require an additional interface module (£35+VAT) or use of an existing wideband meter such as Techedge/Motec etc...
THE INTERFACE TECHNICAL SPEC....
The ecu can accept a 0-5 volts input for the wideband from an external device
or can use RS232 interface to get the relevant data.
Originally Posted by SECS
FYI...
I am currently doing long term testing of this upgrade to be sure it is ok.
So far so good.
Software upgrade will be available within the next few weeks. (BETA version)
The interface (if reqd) will be a while yet as I am busy with coilpack drivers
So far so good.
I dont need the interface as ive got a techedge anyway mate, so no worries there.
Got any hints for me on a good way to do a det can setup on the cheap?
bit of copper tubing and a pair of headphones?
Originally Posted by rsrob
will the new ecu have the coil pack driver option or will i have to buy it seperate ??
sorry for hyjacking the post
Mark RS
12-10-2015 06:01 AM
