what sorta price am i looking at to use -6 braided hose...
..and aeroquip fittings from the fuel rail to the fuel pump on a 2wd sapph cossie?
Hows your car coming Rich
I hav just got a R&D straight cut box 6 speed direct top
I am waiting for the funds to to come in mate and i am getting a peddle box so i will have some off that cool piping mate
Rich,
Fuel rail is being taken care of
I would've it would be a female fitting to the rail, then a male fitting to the fuel pump, then a male fitting to the fuel filter, with another mail fitting out to the fuel pump??
Obviously with hose in between.
is -6 6mm internal diameter?
Mike,
It's a male fitting on the fuel rail.
Then you use a male adaptor on the fuel filter outlet.
If you want to do the pump to filter in braided, it gets a little more complicated, as you can use a bar with banjo bolts, or hose with fittings, depending on where you're putting them.
Seveneights - car is coming along very slowly. Should be there soonish hopefully.
