400bhp engine value?
Old May 17, 2005 | 04:43 PM
Rhys's Avatar
Rhys
Default 400bhp engine value?
Say a very low mileage engine for 400bhp complete with everything turbo etc etc. What would it be worth?
And no its not for me
Old May 17, 2005 | 04:46 PM
SPADGE's Avatar
SPADGE
It would greatly depend on the spec Rhys as one so called 400hp engine and another can be poles appart on spec/price!
Old May 17, 2005 | 04:49 PM
Rhys's Avatar
Rhys
True all i know its supposdly 400bhp spec. So i would presume everything has been done Will have to find out more info on what exactley is done
Old May 17, 2005 | 04:53 PM
SPADGE's Avatar
SPADGE
Rhys there are loads of people out there running 2 bar of boost on a T34 and greys who think they have 400hp so i wouldn't assume anything mate!
Old May 17, 2005 | 05:49 PM
The Gravedigger's Avatar
The Gravedigger
Isn't that because they HAVE got 400bhp?
Old May 17, 2005 | 05:57 PM
abdr500's Avatar
abdr500
i would say about Ł6000/Ł7000
Old May 17, 2005 | 05:59 PM
Westy's Avatar
Westy
no chance
TIFF's Avatar
TIFF
Chasing Radders
Not at all mate.
I run T34, Greys and a touch over 2bar of boost, but i know it isnt 400bhp.
Its around the 360-370bhp mark
Old May 17, 2005 | 06:00 PM
The Gravedigger
For a possibly standard-bottom-end engine with a T34 and greys nailed to it?
Cam's Avatar
Cam
Default Re: 400bhp engine value?
Ł4k to Ł5k if its a proper spec 400hp(headwork, cams, pistons etc) low mileage (5000ish miles) motor with everything - turbo/injs/ECU+chip etc.
Ł7500 to build a motor like that so worth 60to70% of build cost imo.
Old May 17, 2005 | 06:02 PM
The Gravedigger
Not at all mate.
I'm sure I've heard plenty of talk about 400bhp on T34 + Greys, assuming ported & polished head, Mongoose, RS500 i/c etc.
I dunno
Old May 17, 2005 | 06:04 PM
TIFF's Avatar
TIFF
Chasing Radders
Thats it mate, you have heard the talk
Old May 17, 2005 | 06:06 PM
Cam's Avatar
Cam
Not at all mate.
I dunno
healthy std bottom end except for modded pistons/std head fitted with bd14/T34 running 2bar/greys/Rs500i/c and you got 400hp
Old May 17, 2005 | 06:07 PM
The Gravedigger
LoL ok I'll stick with me greens then
Old May 17, 2005 | 06:08 PM
TIFF's Avatar
TIFF
Chasing Radders
Not at all mate.
I dunno
Not with a standard head
The Gravedigger
Not at all mate.
I dunno
So modded pistons, you mean low compression?
Old May 17, 2005 | 06:17 PM
ImaRacing 700's Avatar
ImaRacing 700
Std head will go 400bhp on a t4 and std cams.
Price guide for everything in low milage form 3.5k - 4k
Old May 17, 2005 | 06:21 PM
SPADGE's Avatar
SPADGE
Not at all mate.
I dunno
On a dyno maybe but not in car!
I am running a properly built and mapped engine with a properly ported head, BD14's , 7:5:1 comp, greys and an MD240R @ 2 bar and i doubt its much over 420-430 ish! Maybe i should sell the head,cams and turbo and slap on a T34 if i'm only going to lose 20hp
Old May 17, 2005 | 06:31 PM
Cam's Avatar
Cam
on a dyno maybe but not in car!
reason I quoted that spec makes 400bhp is thats what a mates motor made on the rollers at Nobles about 6 weeks ago. 402bhp/380ftlb.
Old May 17, 2005 | 07:09 PM
Rhys's Avatar
Rhys
I would class a 400bhp engine as my spec, low comp with uprated pistons, lighlted and balanced. Ported head with cam's T34 .63 min. Greys etc.
Old May 17, 2005 | 07:13 PM
Ginge !'s Avatar
Ginge !
just finding my feet
im with spadge and tiff
too many people think that slap some greys, 500 cooler, t34 and they got 400+bhp
the head deffos starts to flow not great after 360ish, this pugo is running NO boost control at all and hes turbo and head are at there max on greys and not making 400bhp
still cant belive hes got no boost control though , braver man then me but he does have a theory that makes sence
he means valve pockets cut out for the bd14 cams to allow em to be timed up, it does lower the compo a tiny weeny but but not anything ya gonna gain from
Old May 17, 2005 | 07:37 PM
Rhys's Avatar
Rhys
Aye a was told a guy was running 400bhp the other week on yellows and a std T3 Awsome bit of work that
Old May 17, 2005 | 07:53 PM
pugo's Avatar
pugo
it wasn't my head it was my fuel pump, my head is wildly ported, i do not genuinly believe a t34 is capable of making over 400bhp for very long! and they definatly will not make it with a -31 actuator.........
spec
is l+b bottom end
7.2-1 pistons with valve pockets
bd14 +bd10
isky springs
big port head by karl norris
polished and peened rods
arp everything
back pressure boost control
my engine is 400specced but i wouldn't sell it for Ł5k..........too much love's/money's gone into it
Pugo
Old May 17, 2005 | 08:35 PM
Rhys's Avatar
Rhys
Why wouldnt a -31 make 400bhp?
Old May 17, 2005 | 08:59 PM
pugo's Avatar
pugo
I run a -31 and the pressure in the exhaust housing lifts the wastegate open at 30psi(at the correct preload).......yes you can wind a bit more preload on but then you get uncontrolled boost creep at high rpm so unless you can hit 400bhp with a t34 at less than 30psi you need a stronger actuator
i meant a -31 with a t34 in the earlier post..sorry for the confusion
Pugo
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
