series 1 box into a FRST???
I am soon to be purchasing a series one gearbox, thats a bit special....
I know it will mount to my block but how will i mount it into my car??! been told its quite ease by to modify and fit...
i have bought a spare FRST box just in case its alot of work?? then i can have the series 1 box completely re-built into the FRST one.....
if anyone can tell me anything on how to fit, i'd be well greatful...
cheers in advance
rich
cheers in advance
rich
Originally Posted by Jano_OddKidd
Direct replacement.
Just make sure you use the right studs in the box!
Regards
Regards
studs are bolts with a thread on one end, and another thread on the other end!
I think what Jano means is the studs at the back of the box, they will prob need changing over.
You can fit a S1 box into a FRST or S2 but not S2or FRST box into a S1. My bro fitted his old Onion up with a S1 box. Improved things dramatically
sorry rich I was being a bit sarcastic there I do admit!
it was just the way you said it. Sounded like you didnt know!
Anyway, good luck wiv the change over hope all goes smoothly!
I hope it lasts more than two weeks, cause its OAP you know!
Just make sure its rebuilt well. theres no point doing these things more than once!
fingers crossed things go smoothly......
it will definately last for a while, OAP
where you from in essex?!?!?!
cheers all... just wanted to know what to change....
i know what a bolt is and i know what studs are
ARE YOU SURE????
irs got a few special parts to it
ARE YOU SURE????
the box i'm told is special, hard as nails, and takes everything thrown at it
Steve Escos
01-10-2015 06:57 AM
Russ Payne
25-09-2015 08:29 PM
