2wd sapph gearbox removal??
Exhaust off, prop off, remove gearstick from box, drain oil out, remove starter,clutch cable,reversing light cable,speedo cable and 6 bolts from bellhousing(17mm socket). Jobs a gud 'un! Found this the easiest way last week,removing the gearstick is easier than dropping the anti-roll bar off,will need to tilt the box down to do it tho prior to removal. Can be done on your own with a trolley jack to support the box.
Mike you knobjockey
Plynchy,
cheers for that.cant wait to get the new box in
the last box we removed there was a chain and landcruiser involved
Plynchy,
exhaust off,prop out,starter off,clutch cable off and reverse switch undone should have the gearbox out tonight
cheers plynchy so far so good
As far as i am aware yes, i never have issues with the mk2.
Even if you do, you can drop the crossmember with the engine on and give your self some room.
Drop the oil first tho LOL.....armpit full of gearbox oil is stinky
Karl 3dr
102
14-10-2016 08:17 PM
FlashRS
13
31-08-2015 06:02 PM
