FAO Water Inj peeps- Mikey Rainbow, etc
DEYTUKURJERBS
Whats the highest pressure WI pump commonly available, and how much?
Pressure (for atomisation) is v.important in this case...
DEYTUKURJERBS
Yes and no Chip. Mainly no
Need to get the atomisation down to about 10 microns, so need a load of pressure.
3bar boost is fairly accurate tho, 7:1comp (down from 8.6:1 std ) and a turbo thats mega efficient at silly high boost
Aquamist ones do 10bar? Jesus, thought others were better...
What you need for cooling is something thats -160 degrees Celcius or so quirted into your engine.
And if it happens to release a massive amount of oxygen too then even better
Going drag racing without nitrous is like playing football without boots
DEYTUKURJERBS
Basicly I need high pressure as poss for as much atomisation as poss as fancy trying some "pre-compressor w.i. hugely increasing turbo efficiency" style japes and dont want to sandblast the wheel
http://www.dualpumps.co.uk/
This is where we buy the flow jets from....they have specs too...
Regards
Ian
The fowjets ae big but very reliable....
Regards
Ian
Caraholic
The Flojet pump is reliable enough to be used in Motorsport applications, where the one Steve mentioned is not...
I don't think that it would be powerful enough to spin up a turbo with a jet on it that was atomising the water to such a fine spray that Steve mentions (if indeed I understand correctly what I think he is trying to do?).
Originally Posted by sibster
So how does a pump overcome frictional losses in pipework etc...?
and why do manufacturers indicate....flow verus pressure?
could you get a pump to make 3 bar outlet pressure with an open end?
LOL, i get what you mean though, people seem to forget the whole flow/pressure thing quite often.
DEYTUKURJERBS
No way you are going to spool a turbo with water, you would have to use SO MUCH water, it would be disastorous for the engine to soak it like that.
Think he been visiting a ye olde cider mill powered by a water wheel and the effects of the scrumpy is still affecting him
All pumps are rated closed head....i realise that....i know where you are coming from gareth but in this instance the pump characteristics display both flow and it will develop pressure....if I took a flowjet....with my nozzles attached and a gauge attached to the delivery line....would I have pressure?
Originally Posted by Doug Stirling
In other words drive the compressor shaft with high pressure water???? If the shaft had ridged splines I guess it could be "driven" by water passing over it at high pressure
Ive told you to lay off it before lunch.
Caraholic
Steve,
I was just being polite . I couldn;t believe you wanted to do that, but wasn't sure if I'd got hold of the wrong end of the stick, as I know you have talked about same with NOS....
Flojet pumps:
http://www.randbmotorsport.co.uk/sho...?ProductID=140
Flojet pumps:
does the nozzle or the pump cause the pressure?
Steve,
Flojet pumps:
Flojet pumps:
DEYTUKURJERBS
Mature sensible Escort Cossie owners in crack cocaine abuse shocker
