HELP NEEDED NOW!!!!!!
Old May 4, 2005 | 10:51 PM
rsjohn's Avatar
rsjohn
Default HELP NEEDED NOW!!!!!!
Im taking engine out of my 4x4 sapphire cosworth and am about ready to pull it out but not sure whats the best way to disconect drive shafts etc from sump!!!
Advise please chaps???
john.
Old May 4, 2005 | 10:53 PM
SPADGE's Avatar
SPADGE
Drop the lot on the floor inc sub frame!
If you try to get it out from above your going to have to loosen the sub frame anyway to get the front diff past it so you may as well do it from underneath!
Old May 5, 2005 | 07:11 AM
rsjohn's Avatar
rsjohn
Still dont explain best way to disconnect from front diff!!!!
john.
Old May 5, 2005 | 07:15 AM
Azrael's Avatar
Azrael
Left shaft schould just go out. Right one - you need to remove bottom cover of the diff and take the circlip out if it wan't removed like on mine. Then you just remove 3 bolts and braket that hold it into the sump and take it out - might need some force..
Old May 5, 2005 | 06:00 PM
rsjohn's Avatar
rsjohn
Is there another way without removing bottom cover on diff??
john.
Old May 5, 2005 | 06:04 PM
rstoughy's Avatar
rstoughy
Drop the whole lot out then go about removing everything.
Mine on the way out (crap picture,sorry )
Old May 5, 2005 | 10:47 PM
rsjohn's Avatar
rsjohn
Well what a bitch that was to do, just got in now!!!!
Nothing would go right for me so ended up with crossmember and brakes etc off and pulled engine out with sump, diff and front prop onit!!!
Got to get new lump back in!!!! gonna be a nightmare i expect!!
john.
Old May 6, 2005 | 09:41 PM
DazC's Avatar
DazC
john.
That is the best way to do it John. Drop the whole lot on the floor and strip the bits off on the floor...
Old May 6, 2005 | 09:49 PM
rstoughy's Avatar
rstoughy
You will probilly find it will go in easier. You have no seized bolts ect to mess you around plus everything should be nice and clean. Just get a mate to come round and give you a hand with lining up everything as you hoist it up into place
Good luck
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
