how heavy is a 4x4 sierra
Old 03-05-2005, 04:28 PM
xr4x4rs
xr4x4rs's Avatar
Default how heavy is a 4x4 sierra
does anyone know roughly how heavy the above is
either xr or cossie just want a rough estimate
thanks
Old 03-05-2005, 04:44 PM
Disabled Account
Disabled Account's Avatar
4x4 Cossie: 1,280 kg kerb weight
Old 03-05-2005, 04:47 PM
marco polo
marco polo's Avatar
If it has the leathers then it weighs even more
Old 03-05-2005, 05:22 PM
xr4x4rs
xr4x4rs's Avatar
so if i was to strip it out then
with 1 seat and harness what do u think it could be
Old 03-05-2005, 05:25 PM
DangerousBryan
DangerousBryan's Avatar
how can a cossie weigh 1280kg? or is that just out of a book.my xr 4x4 with me in it and half a tank of fuel weighed 1440kg on the weigh bridge at work.and that was a gls so no abs or rear electric windows or electric roof.
Old 03-05-2005, 05:29 PM
markk
markk's Avatar
dangerous,
Old 03-05-2005, 05:53 PM
Disabled Account
Could be that my book is wrong "The Cosworth Fords - by Jeremy Walton"....
This is what it shows:
Old 03-05-2005, 06:08 PM
richm
richm's Avatar
2.9 XR4x4 (hatchback) is quoted at 1290kg kerbweight
According to the UK Construction and Use Regulations 1986, kerbweight is the "weight of the vehicle as it leaves the manufacturer with full fuel, adequate lubricants and water, standard tools and equipment but no driver, occupants or load".
Old 03-05-2005, 06:18 PM
markk
markk's Avatar
so even there a discrepancy of 10kgs - give it another 10 publications and it will be under a ton !!
Old 03-05-2005, 06:21 PM
richm
richm's Avatar
Mark, the 1290kg is for XR4x4
I agree with Doug, the figure I've seen officially quoted for 4x4 Saph is 1280kg..
not saying these are neccesarily actually correct in 'real world' terms, but they are the published kerbweight figures.
Old 03-05-2005, 06:59 PM
pee vee
pee vee's Avatar
the XR4x4 has a dirty great V6 2.8/2.9 in it though
so the cos should be lighter than that id say.. prolly not a lot though ?
Old 03-05-2005, 07:14 PM
DangerousBryan
have you tried lifting a 200 block? mine was a tt though so probably a bit heavier than standard.my mate did this with an xr2 and managed to take 85kilos out of it before putting two bucket seats in it.so you might get 140-160kilos out of a cos.my power to weight was 180 bhp?ton with 260bhp.so to crack 200 per ton you might need about 300bhp to start with?
jessie_rs
62
06-08-2019 09:27 PM
truffleshuffle
10-09-2015 09:35 PM
Escortdriver1
06-09-2015 10:12 AM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: how heavy is a 4x4 sierra
