General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
im trying to do a turbo conversion on a mk5 rs2000. i have cut and shut the 2wd inlet and fuel rail to fit now i find out 2wd injectors have low impendence and will fry the ecu!
just came across a omex ballast resistor that coverts high to low! anybody know if this will run with the rs2000 ecu? (im bl**dy detemand to run cossy injectors without buying a after market ecu)
Running low impedance injectors with a ballast resistor will be MARGINAL on the EEC4 ecu.
Also, this will reduce injector efficiency which will make them HARDER to map.
