Need garage to fit new rear bushes and Mike rainbird shims..
Old 27-04-2005, 06:07 AM
  #41
When we tested the shims, we didn't test all the geometry, just the feel of the car.
PLaced in back 2 bolts to toe in the front of the wheel slightly....
Koni's and GRPA Tarmac Billies...
Honest answer - 3 people drove, not one person noticed any change in feel, hence the waste of money, think they are only a tenner tho so not too bad.
Old 27-04-2005, 07:14 AM
  #42
Kevin B
Kevin B's Avatar
Cant really comment on how they affect the handling as we did all the suspension at the same time, but it has certainly improved rear tyre wear on my 4X4 Saph
Old 27-04-2005, 07:51 AM
  #43
Neil S
Neil S's Avatar
They made mine handle distinctly strangely (4x4 Saph).
Felt like it had much less grip at the back if anything
Yes I did fit them correctly!
I think they're probably still in the paddock at Croft rusting away quietly!
Neil.
Old 27-04-2005, 08:00 AM
  #44
Kevin B
Kevin B's Avatar
Mine does slide more now, but I put that down to the coilovers/whole new suspension set up
Old 27-04-2005, 08:02 AM
  #45
Neil S
Neil S's Avatar
This was under mid-bend, light/medium throttle conditions, and didnt make me horny at all
It must just be me though, as everyone else is raving about them
Neil.
Old 27-04-2005, 08:30 AM
  #46
rs cos
rs cos's Avatar
i fitted them to my old 4x4 saph, noticed it was a wee bit better in a straight line at high speeds! now mike you owe me a pint
Old 27-04-2005, 08:37 AM
  #47
If its improved tyre wear it certainly sounds like its going to help straight line launches as both launching and tyre wear rely on having the full tyre in contact and tracked pretty straight, handling is a lot less simple though and is often the opposite, especially where camber is concerned.
Throw in the fact that the geometry all changes as the suspension compresses and it gets to be more of a nightmare, so basically trial and error is often the best way, so if the shims work for others its worth trying it at least, although i suspect that the manufacturing tolerances on the beams etc are far enough away from car to car though that you probably need a different thickness to suit your car really and probably different on each side too, mass produced cars are pretty shonky really, especially cheap and cheerful ones like a sierra.
Old 27-04-2005, 09:51 AM
  #48
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
Neil.
same here. when I launched the car it felt like it it would crab slightly and when letting off after hard accelerating the car felt really light and horrible
mine are also sitting some where rusting away.
cheers
Old 27-04-2005, 09:55 AM
  #49
RichardPON
RichardPON's Avatar
I think the lesson is this though.
Don't try and correct the camber if it doesn't need correcting.
Mike'll be the first to tell you that it's a little unscientific to put the shims in without knowing how out of whack (if at all) the settings are...........
..... and before anyone starts, this is cossies we're talking about, so you can bet your ass that not one of them is particularly straight
Old 27-04-2005, 09:58 AM
  #50
Mass produced 80s litter sadly
Old 27-04-2005, 10:44 AM
  #51
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Well firstly, you're supposed to check the geometry before and after , as you are trying to achieve a small amount of static toe-in. This is because when moving forward, the bushes deflect and this will then give you the parrallel setting that Ford recommend. If you set a Cossie to parrallell statically, the bush deflection causes the wheels to toe out, which scrubs the inside of the tyres, causing the wear on the inside edges that all Cossies seem to suffer from.
Obviously if your car has more toe one side than the other (due to a bent trailing arm or such, which is COMMON on Cossies, as they're not the strongest of items), then fitting these shims will exagerate that and WILL cause unusual handling characteristics .
As to stating they don't do anything, well if you take a photo before and after you can physically SEE the difference in the camber (less negative ), so saying that you need 4mm shims to achieve this is crazy, as that would put so much load on the hub to the point that I would personally consider it dangerous.
The shims do exactly what I state, if fitted correctly and the geometry has been checked and is as it "should" be .
1. Improve tyre wear.
2. Improve traction.
3. Improve on the limit handling (slides are easier to recover / control).
Old 27-04-2005, 11:09 AM
  #52
Camber is were the top of the wheel is not 90 degree's to the floor aint it ?
How does the shims alter this ?
Old 27-04-2005, 11:11 AM
  #53
Neil S
Neil S's Avatar
I have the geometry data from my setup at home, I'll post it later, but it was roughly within spec, and was certainly straight
Neil.
Old 27-04-2005, 11:12 AM
  #54
Neil S
Neil S's Avatar
Beacuse one of the shims goes ABOVE the centreline of the hub axle
Neil.
  #55
Jim Galbally
Jim Galbally's Avatar
by making it not 90degrees to the floor
Old 27-04-2005, 11:17 AM
  #56
JAP CRAP
JAP CRAP's Avatar
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
MIke, my tyres wear badly on the inside. I take it these would sort this??
can you fit them for me?
Old 27-04-2005, 11:25 AM
  #57
same added from both sides of the axle tho, from top to bottom.
Old 27-04-2005, 11:35 AM
  #58
Turbo lag
Turbo lag's Avatar
Can you do the work on my car Mike,
and how far are you away from Preston ?
Dave.
Old 27-04-2005, 11:47 AM
  #59
JAP CRAP
JAP CRAP's Avatar
You have to have slept with Mike on more than 10 occasions to get his special services im afraid
Old 27-04-2005, 12:27 PM
  #60
Mike Rainbird
Caraholic
Dave,
I'm 230 miles from you .
Dom,
You're still 3 sleeps away from the required amount .
Old 27-04-2005, 12:49 PM
  #61
Nice answer to my q mike and PMSL @ you working on car...
Do you know the difference between a screwdriver and a hammer
Old 27-04-2005, 12:53 PM
  #62
As far as i can tell mike is good at knowing what needs to be done, but feck all use at doing it so gets other people to?
Is that about right?
(its what his mrs said anyway)
Old 27-04-2005, 12:56 PM
  #63
Neil S
Neil S's Avatar
LOL @ Chip - thats right - He even gets the guy at the petrol station to fill it up in case he breaks a nail!
Ill take this then:
Neil.
Old 27-04-2005, 12:58 PM
  #64
Mike Rainbird
Caraholic
I have an obsessive compulsive disorder where I don't like getting my hands dirty . However, when needs must and all that, I do actually work on my own car (much to the surprise of everyone, as the cameras all come out if it is at a trackday etc ).
Old 27-04-2005, 01:05 PM
  #65
Furry Muff, you can clean the screen, after visting PONBEACH
Now please explain by placing the shims in a cossie it alters the camber when the are placed in the back half of the flange that bolts to the wheel.
Old 27-04-2005, 01:10 PM
  #66
CozzyBrom
CozzyBrom's Avatar
thats funny mike i take it u have scrapped the zoo beam then
Old 27-04-2005, 01:20 PM
  #67
Mike Rainbird
Caraholic
Steve,
Go figure it out yourself .
Brom you moron, why would I want to do that . It is FAR superior to the shims and I wanted the BEST way of adjustment, hence the Zoo beam is on my car. The shims are are a halfway house and at Ł10 are a good idea to improve the inherent flaws in the standard set-up (without the expense of a replacement beam), but they do not fix the way the suspension proscibes an arc in it's up and down movement, which the Zoo / Ahmed beam does .
I have only ever advocated the shims as a cheap and cheerful way of improving things, so have no idea where you're coming from .
Old 27-04-2005, 01:24 PM
  #68
Neil S
Neil S's Avatar
The only way I can think of is if the hub mounting holes were moved enough (as the supension compresses) to get the one that is normally top rear above the one that is normally top front. If you follow me.
Neil.
Old 27-04-2005, 01:31 PM
  #69
CozzyBrom
CozzyBrom's Avatar
mike
i am not sayin that your saying there better
but you state u have them on your car and it handles loads better
so have u fitted them aswell or did you have them fitted before becuse when i fitted the beam there was no shims there
as for armed beam i carnt say i have only eva seen warren kellys and personally dint think it was up to the job
no strapping no toe in ajustment i dont no what pick up points he used but i coped mine design of a rs500 add extra bits to the normal beam
we do a road beam with out strapping now which is alot more easyer to make and is loads cheaper
Old 27-04-2005, 01:32 PM
  #70
How much does a Zoo beam cost?
How significant is the difference as ive not ever been in a car equipped with one?
  #71
RichardPON
RichardPON's Avatar
Shut it slaag
I think Mike just prefers "project managing" other people - hence why we were all changing his brake discs at the Ring, and he was pacing up and down like a taskmaster!
Old 27-04-2005, 01:33 PM
  #72
Mike Rainbird
Caraholic
Brom,
I had them on my Sapphire before I had the Ahmed beam .
Rich,
As I said, when needs must I do get my hands dirty (translation: when there is no-one else around willing to get their hands dirty ).
Old 27-04-2005, 01:35 PM
  #73
Neil S
Neil S's Avatar
LOL @ PON
This is how I meant:
Neil.
Old 27-04-2005, 01:37 PM
  #74
So then Mike, you add shims to the front or rear of the wheel, and it causes toe-in....
As your shims create camber - i think its not possible..
The rear beam drops thus creating toe out and making the wheels straight rather than toe-in which is what you are doing.
With out the shims the wheels when sinking do this create toe out when squating ?
Old 27-04-2005, 01:38 PM
  #75
CozzyBrom
CozzyBrom's Avatar
chip theres loads out there
beam start from Ł550 for a road beam no strapping
rally beam Ł750
race tublair beam Ł850
then jag beams Ł1050
mike
paul egg
wez
martoon
me
sean b
loyed
jamsport
rod tarry
karl n
doug
loads
and far more off the site
most beams i sold are to rally boys wanting the brom aproach
Old 27-04-2005, 01:40 PM
  #76
550 doesnt sound like a lot of money if it sorts out a genuine problem
  #77
Thought matron had a proper beam now brom
Old 27-04-2005, 01:41 PM
  #78
Mike Rainbird
Caraholic
Steve,
Why don't you measure the toe / camber of the car you were going to fit them on, re-fit them and then come and report the results .
Old 27-04-2005, 01:42 PM
  #79
CozzyBrom
CozzyBrom's Avatar
he does now as he has built the car around it
to the cage
but he has it on his old one
Old 27-04-2005, 01:43 PM
  #80
CozzyBrom
CozzyBrom's Avatar
yes it does sort out the problems
and all beams are made in same jig and all uses same pick up points
Quick Reply: Need garage to fit new rear bushes and Mike rainbird shims..
