too much pedal travel
the brake pedal..
Just recently when I push the brake pedal, nothing happens until its near the bottom.. I can pump it once, then it works perfectly. They work fine but abit annoying as I want instant braking not a second later once the pedal is near the floor.
Hmmm, had all sorts of funwith mine converting to rear discs: Still not 100% similar to what you are experiencing. I'm hoping when my 300mm front setup goes on and the abs is removed it will cure the problem
air in system. if bleeding them (properly) doesn't help, its likely your master cyl is fubared. i managed to f**k my M/S on the XR4i when bleeding them, new (well, from the scrappy ) cured it.
westy its simple, it IS air in the pipes, you just gotta work out if thats caused by poor bleeding or if something is broken.
when he replaced the lines, he should have bled the system... i see two possibilities:
1) he didn't
2) when bleeding the system the M/S got shagged (v. common)
1) he didn't
massivewangers
30
01-10-2015 07:40 PM
