Cossie T5 Box problem......
Old 26-04-2005 | 12:14 AM
boXXer's Avatar
boXXer
GASH!
Default Cossie T5 Box problem......
Ive noticed that my g.box is being a bitch when trying to get into 1st a lot of the time, then yesterday, it just wouldnt go in at all. Does anyone have any suggestions on what this could be? when i did manage to get it into gear, it nearly got stuck and i couldnt get it out again. Would oil cause a problem like this, or is it more serious?
Mike
Old 26-04-2005 | 12:51 AM
pugo's Avatar
pugo
i take it the clutch isn't dragging?????????
if it isn't then i suggest a phone call to 'bernie the box' as it will be a selector problem
Pugo
Old 26-04-2005 | 03:16 AM
wildheart's Avatar
wildheart
we all told you not to run it at central day incase you did any damage to it
Old 26-04-2005 | 08:04 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Could be a baulk ring mate. Couldnt get mine in 5th. Felt like a solid object was in the way sort of thing. Call Bernie the gearbox man
Old 26-04-2005 | 08:29 AM
boXXer's Avatar
boXXer
GASH!
PMSL! shut up. Dont think it was central day anyway, cos its been a bit like it since i bought it.
Kevmk2 mentioned it could be the bulk rings as he knew someone that had the same problem. Is it an expensive fix?
Mike
Old 26-04-2005 | 08:31 AM
CossieRich's Avatar
CossieRich
Its a Ł12ish part mate. More labour than anything really
Old 26-04-2005 | 08:49 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If it only is difficult to select first gear whilst stationary (i.e. it goes from second to first no problem while moving), then it is likely to be the clutch dragging.
This can be caused by four things.
1. Flywheel has hot spots on it that need surface grinding to remove.
2. Clutch cable has stretched not allowing the clutch to disengage properly.
3. Ratchet isn't adjusting correctly on clutch peddle.
4. Clutch is fucked.
A combination of all four of the above .
Old 26-04-2005 | 05:57 PM
boXXer's Avatar
boXXer
GASH!
hmmmm, will have to try that one. Cheers mate....
Mike
`spotty
26-09-2015 12:41 AM
landaqmabba
15-09-2015 08:16 PM
Cos500
15-09-2015 07:47 PM
andrewmctiernan
08-09-2015 04:05 PM
Rizlablue
06-09-2015 10:58 AM
