who here has made there own wiring loom????
just finding my feet
ok i need to know aboyt the connections for the loom and what there called
should have actually pmed you christian as im redoing the loom i got off you asn adding new parts
where can i get the conectors from and do they come complete
if i new this was gonna be this long i would hae turned me phone off
Depends what you want the loom for? If it's an engine control loom, they have to meet a certain standard by being made out of certain wiring in a certain way otherwise you risk melting the engine due to EMF interferance fooking the sensor signals up.
Only actuating units on the engine can use copper wiring without problems (like injectors).
I bought all the connectors from a local auto electrical suppliers, 30 quid the lot. they come in component parts with plenty of spare pins in case u make a balls up. Bought the nylon sleeving from demon tweeks (looks like string) and it finishes it off nicely
whats the connections called
whats the difference in thw wiring for a loom then ???
i know the cps needs to be shielded but the rest looks normal
The only wires in my loom that are shielded are the ones to the crank pick-up & the dizzy. I just called the connectors 'Bosch type' & the guy had a catalogue with pictures in it so i couldnt go wrong. think the company that makes em is called Durite, red labels on the packs anyhow
The ones as used by Pectel and Ford plus most other manufacturers are a different make however and also different colours.....nothing wrong with the Durite ones however as I have used loads in the past!
pmsl
that was alot of consutancy
need them sizes again though as my fooking pc crashed when i went tosave it
but i managed to save the web page though
pmsl
Send me a PM and I'll disclose the info again!!
Fudgey
17-09-2015 01:06 PM
