Combrake brake kits any good??
Wish I had more time!
Hi,
as stated above want to upgrade my brakes but not sure if these are any good? Only for road use not tracking the car? Any reviews or personal experiences? Any insight would be appreciated cheeRS
Hi mate thanks for the reply, they do look good but seen on here some people saying that they weren’t very good back in 2010 mark, just wondering if some one has more up to date experience on the kits? If that makes sense?
hi mate thanks for the reply, my only reserve is that they are a lot cheaper than the equivalent ap racing kit, they can’t be that different in quality do you think? In regards to the hawk pads what’s your verdict on them? Is it possible you for different branded ones or do you have to stick with them?
That’s great thank you for sharing your experience with them, I’ll think I’ll go with these then it’s only ever going to be road use, do you think I’ll need to upgrade the servo and master cylinder from standard to accommodate the bigger brakes?
That’s interesting to hear! Thanks very much for the reply, seems that combrake have ironed out the issues we’re posting about before so I think I’ll go with them.
I also run a bias pedal setup too. Don't try to add 4 pots to the rear of an RST
Not needed
Ah right I see that could have been disastrous on my part couldn’t it! 🤣 so you think I’ll be alright with these up front drums on the back and the standard servo etc?
As someone else has said make sure you get the right brake pads with the kit. The car is set up for road use so you need pads which work well from scratch. Looks like a good kit you are going for.
thanks for the reply I will ring combrake tomorrow and tell them my intended use and hopefully this will advise on the right pads for me 🤞🏼
MAD EVO 4
11-02-2007 06:47 PM
