Techie Q...How much power do you loose RWD.......
Flywheel to the wheels ?
Kel said somert bout 15%
Is this about right...
My car made 320 at ava so this points to about 370 @ the flywheel
There isnt a hard and fast figure, its not an amount of a perentage, its an extremely complicated equation containing oil viscocity and temperature among other things.
15-20% is a good "rule of thumb" though.
Originally Posted by Matt
rainbums was 395 wheels at ava werent it and 515 on dyno
@ 373 wheels on a t34 car, take it to ava
LOL at 45psi . Just out of curiousity, what gauge was that measured on ?
My turbo don't run 45psi ever LOL.....
38 peak...
Dyno is ok for a bench mark in performance but very far from actual power in car IMHO...
Mine made 405 on dyno and made more at the wheels at AVA than any T34 car (think this still stands) Be good to see what its like now
38 peak...
Originally Posted by Christian and Beccy
But whats the relevance. Apparently Rolling Road figures aren't worth shit.
I mean karls made 540 @ wheels +20% = 648 on low boost
Ring any bell's?
RST's normally lose between 25-35bhp through the transmission, depending on Tyre's, Gearbox Oil/Temperature etc.
Jb Fletch Postin...
The T35 on me old engine used to love boost in a big way (ask anyone who went in it), went off the scale of my 2.5 bar gauge and when I was down Powers one day with a friend they let me stick their gauage on mine to run it up the road. Bang on 3 bar which is about 43.5 psi. It had been on the dyno & 2 or 3 rollin roads producing in excess of 420 hp on each. I was happy
AVA might be the daddies on the Rollin Road but fook drivin all that way bruv !
Jb
Jb
Biggest loss of power is via the tires, around 5-6% of total power loss. The transmission accounts for around 2%, the differential another 3% and then there is the prop shaft and joints and oils take the rest away.
I found this formula to be the most reliable.
Crank HP - 12% (if RWD, 10% if FWD)
- 10 hp
= horsepower at the wheels
- 10 hp
because i am. dont have to be right to be sure.end of.
Re: Techie Q...How much power do you loose RWD.......
surely the loss stays the same no matter the power.
why would a car with 600 bhp lose more thru the transmission than a car 400bhp?
my car makes 290 on AVA RR but will make a GOOD deal more in the next couple of months.
i wont be adding more to the figure tho will always just add 30bhp.
ok say a car that makes 1000bhp loses 20% thru the transmission..thats 200 bhp.
that amount of heat would melt the box!
rapidcossie,
helical gears which try to push thenself appart,, give them more power,, and they try even harder to do so, increasing thrust loading,
thats just one example
#1 in Spelling Club
e.g. A FWD car with 130bhp, but very cold, thick Gearbox oil will have higher losses than a 300bhp FWD car with a nice warm Gearbox.
At the end of the day, although more power will equal slightly higher losses, that car is still essentially running that same tyres, the same gearbox, the same driveshafts etc. So the losses shouldn't really be that much different.
it depends on a shit load of variables.....
condition etc of gearbox, diff....
weight of the driveshafts/wheels....
pretty much the weight and mechanical condition of every moving componant between the flywheel and the tarmac........
so there's no percentage or given figure, that's bullshit....i know of a freelander [yeah shit i know, but keep reading.......] that made 44bhp at the wheels due to shagged transmission, the engine was absolutly fine.......
deathrider666
28-09-2015 06:12 PM
