25k Sig limit?
Right, first off, this aint a dig at anyone!
I fully understand that the site costs money to run, and the more images etc it shows, the longer it takes to load, blah blah, thats all cool, and a bit up to Pet and Stu for doing it
But!
Ive been making myself a new sig, finished it, then uploaded it, and remembered it had to be under 25k... back into photoshop i went, resized it, compromised a bit of image quality, and checked the filesize.. 32k bugger. Tried again, resized it, cut the quality a bit, still 29k.
Finally got it to less than 25k, and this is the outecome:
![](https://i4.photobucket.com/albums/y111/Cold0/coldopass.jpg)
Shocking quality, you have to agree?
Either, im doing something wrong?, or the 25k limit is taking the piss a wee bit?
Agian, no offence intended, but in my honest opinion, 35k would be alot better, and shouldn't really affect loading times greatly? Especially, as i assume most* are on some form of broadband?
But!
It might just be the way your using your photoshop skills mate.
ask Madmac or Billabong or Thrush for info on photoshop - they are the sig meisters.
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
As said, some of the sigs on here are really good, so I'm sure someone can help,
Phil has offered
When you save the file as a JPG turn the LZW compression down from high to the lowest setting. that should help.
I had the same problem and ended up with a postage stamp size sig
Daniel
Daniel
i REALLY struggles to get photoshop to save a sig smaller than 25k! even on lowest compression!
i THINK its something to do with NTFS... the file size is estimated 16kj ish but when i save it to disk it always goes to about 28k
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![](http://img159.echo.cx/img159/6138/coldopass9ym.jpg)
W'a jammin lads.
Cheers, should have been using the save for web option insted of just lowering the compression after saving as a Jpeg.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
SMILER258
28-09-2015 09:04 AM
