Closed cell foam insulation
I dont think closed cell foam would have enough mass to stop the deeper noises resonating through the floorpan, could be wrong. I've seen it used in sills etc. Ford tend to put bags of closed cell insulation pieces in sealed plastic bags, and rigid closed cell blocks are oftend bonded to the inside of panels, i think thats more to reduce the cheap metallic vibration sounds when shutting doors etc though.
Fleet Manager
Its mainly for the padding as apposed to sound deading i cant cover it with dynamat or similar just need a way to pad outbthe caroet as i wont be reusing the original stuff
I think it would be fine for just padding, as long as it's going to remain springy after continued use. You might even be able to find a foam layer that;s backed with something else to add mass. For what reason cant you use bitumen style pads, keeping weight down/future welding planned?
Fleet Manager
Hi Marky, what are you looking to achieve? Just padding out the carpet a bit?
Closed cell works well under carpets and wont absorb any water should there be a leak or anything spilt.
We use it extensively when we sound deaden cars
Have a look at this to see how we did our Orion https://passionford.com/forum/restor...d-finally.html
We used semi closed cell foam to help absorb road noise.
If you need to source anything just give me a shout
Glad you turned up Bassboy with some detailled knowledge, I thought of you when I read the title but didnt know if you were still active on here.
bassboy (19-09-2019)
Fleet Manager
Ffs i dunno why i didnt ask you in the first place lol, im binning the original sound deading/padding as its ruined and im just looking to replace it with something more modern ill checkout the link lol
fatboyz
21
13-10-2007 06:01 PM
