2wd Cossie 6 degree rear beams
As per title were/are they as good as they were made out to be for a fast road cossie? I seem to remember the suspension of choice was the bajoo set lowering it by 25mm.
anyone still on here that had one fitted did you notice any difference?
Yes, they can make a big difference.
Ahmed bayoo designed the first all others after were copies variations of his
Rod did 0-100 mph in 6.86 seconds which as far as I'm aware grip wise alterations on the rear was coilovers, 6 degree beam, Jag diff and r888s, it must help get the power down
scoooby slayer (31-08-2019)
That is actually not the reason that the beam helps reducing understeer. On the standard beam not only the camber change is big, but also the toe change over the suspension travel. And it is the toe change that causes the understeer. The toe change is also a lot less on the 6 degree beam, that’s why it helps reducing understeer.
Sponsor
You contradict yourself the agree with me lol . I've seen pics of yout car in corner so I'll stick to what I know as you could write what you know about suspension settings ect in a match box and still have room to write a 4 course meal on if
Received 1,044 Likes
Now now boys. I've fitted camber shims to my rear beam/hubs and the wheels defo sit better in the arches. Poly brushing the standard beam and a poly diff mount also made a massive difference on my saff.
From jays spelling I'd say he was pissed up.lol
If you can get one fitted, geo’d up etc I’d definitely recommend it
