Brake fluid
Evening all, I have been having issues with my brake servo pump on my cosworth. When sitting in traffic for periods of time the pump cannot reach the pressure switch cutoff pressure 180bar I believe. I have read about this happening when there is no heatshield to protect reservoir but I have the original in place so you would have thought this should do the job.
The voltage at the pump is good and the fluid (Dot 4)in clean about 8months old. The pump has no problem when cooler so I was wondering if there is a better brake fluid I could use to remedy this problem?
Any help is much appreciated.
Tim.
Tim.
Thanks , yes I think there is air in system. I have bleed the system twice now, and on the second time I bleed the system the front left had more air in it and it took about 5 or six depresses of the pedal for pedal to firm-up.
I will try and bleed again in a couple of days and see if any more air in evident.
Can you still buy a master-cylinder rebuild kit? Although there are no leaks anywhere so could just need to keep bleeding?
Thanks for your help.
Tim.
Tim.
Tim.
Tim.
Martin
paulshears
23-03-2009 06:17 PM
Char1ie
24-06-2008 02:40 PM
