Fan on B Max
Fan on B Max
I think I've asked this before, but it keeps happening and I don't know why. Almost every day the fan keeps going for a few minutes when I park the car. Noisy at times too, I see people
staring as I walk away from it. It's not as if I have been far too. Sometimes just about 3 miles to the supermarket and back home. Someone said it's natural for the Fords but maybe a mechanic might explain why this happens.
Thanks Glen, I am just curious that it stays on when the engine isn't even hot. But if it's a trait of Ford no need to worry.
Received 1,042 Likes
Some info for you. This user has the same problem when the car is switched off.
https://talkford.com/community/topic.../#entry2893673
Thanks Glenn, that's interesting as the reply said it was normal. Thanks for the link.
That's interesting, yes most of the week I am just doing short runs, I remember the mechanic at the Ford garage saying I need to run up and down the dual carriageway and open it out at least once a week. Specially as it was a diesel car.
If its trying to regen and you keep interrupting it the the dpf will eventually block and leave you with a huge bill for a new one. As said you need to give it regular long runs, if mine is doing a regen and I am at my destination then will drive round the block a couple of times while it finishes.
VR46 The G.O.A.T
My 3 series BMW does the same every now and again. Couldn't work it out to start with and then I realised it must've been part way through a regen.
As advised take your car for a decent run preferably on a motorway where you can keep a consistently high enough speed for the regen to complete.
Not sure how it works on the Fords but BMW's just need to be up to operating temperature and the speed kept higher than 38mph for the process to start and then complete.
kosienutter
12
04-05-2013 10:50 PM
